Error Failed to execute MI command: flushreg
Rasoul
I want to program S32K358 NXP MCU. After pressing Debugging bottom I faced to the following error:
Error in final launch sequence
flushreg
continue
monitor refreshviews
continue
Error message from debugger back end:
Remote communication error. Target disconnected.: No error.
It seems that it is related to the Flush register. I tried different ways to fix it but I couldn't. So, I appreciate it if somebody help me in this regard.
Thanks!
Tags (2)
Rasoul
For those who encounter a similar error, this issue arises from the lock pin on the NXP evaluation board. There is a switch that disables the MCU from being reprogrammed. If this switch is ON, you will encounter this error during debugging and programming of the MCU. To resolve the issue, you must deactivate this switch on the evaluation board.
jiri_kral
what is your debug probe?
Rasoul
%3CLINGO-SUB%20id%3D%22lingo-sub-2017255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EError%20%20Failed%20to%20execute%20MI%20command%3A%20flushreg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2017255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20want%20to%20program%20S32K358%20NXP%20MCU.%20After%20pressing%20Debugging%20bottom%20I%20faced%20to%20the%20following%20error%3A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EError%20in%20final%20launch%20sequence%3CBR%20%2F%3EFailed%20to%20execute%20MI%20command%3A%3CBR%20%2F%3Eflushreg%3CBR%20%2F%3Econtinue%3CBR%20%2F%3Emonitor%20refreshviews%3CBR%20%2F%3Econtinue%3CBR%20%2F%3EError%20message%20from%20debugger%20back%20end%3A%3CBR%20%2F%3ERemote%20communication%20error.%20Target%20disconnected.%3A%20No%20error.%3CBR%20%2F%3ERemote%20communication%20error.%20Target%20disconnected.%3A%20No%20error.%3C%2FP%3E%3CP%3EIt%20seems%20that%20it%20is%20related%20to%20the%20Flush%20register.%20I%20tried%20different%20ways%20to%20fix%20it%20but%20I%20couldn't.%20So%2C%20I%20appreciate%20it%20if%20somebody%20help%20me%20in%20this%20regard.%3C%2FP%3E%3CP%3EThanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2031242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Error%20%20Failed%20to%20execute%20MI%20command%3A%20flushreg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2031242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFor%20those%20who%20encounter%20a%20similar%20error%2C%20this%20issue%20arises%20from%20the%20lock%20pin%20on%20the%20NXP%20evaluation%20board.%20There%20is%20a%20switch%20that%20disables%20the%20MCU%20from%20being%20reprogrammed.%20If%20this%20switch%20is%20ON%2C%20you%20will%20encounter%20this%20error%20during%20debugging%20and%20programming%20of%20the%20MCU.%20To%20resolve%20the%20issue%2C%20you%20must%20deactivate%20this%20switch%20on%20the%20evaluation%20board.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2031238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Error%20%20Failed%20to%20execute%20MI%20command%3A%20flushreg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2031238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFor%20those%20who%20encounter%20a%20similar%20error%2C%20this%20issue%20arises%20from%20the%20lock%20pin%20on%20the%20NXP%20evaluation%20board.%20There%20is%20a%20switch%20that%20disables%20the%20MCU%20from%20being%20reprogrammed.%20If%20this%20switch%20is%20ON%2C%20you%20will%20encounter%20this%20error%20during%20debugging%20and%20programming%20of%20the%20MCU.%20To%20resolve%20the%20issue%2C%20you%20must%20deactivate%20this%20switch%20on%20the%20evaluation%20board.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2022603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Error%20%20Failed%20to%20execute%20MI%20command%3A%20flushreg%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2022603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ewhat%20is%20your%20debug%20probe%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
