Debug kinetis with segger VLLS
danielecortella
Contributor V
i have a KL46 that enter in VLLS1. I'm debugging the micro with a segger j-link and my question is if it is possible to mantain the debugger on so when the device will wake up i can resume the code analisys. I'm using kds 3.2
SOLVED HERE!!!
https://mcuoneclipse.com/2015/03/20/attaching-to-a-running-target-with-segger-j-link-gdb-and-eclipse...
