Connection Error using Multilink Universal with Kinetis MKV46F256VLL16 processor
已解决
跳至解决方案
1,678 次查看
boubacarhoussei
I want to directly program the MKV46F256VLL16 processor on the TWR-KV46F150M board through a PEmicro USB-ML-Universal Interface. I got connection error when launching the Debug Configurations using KDS 3.2.0.
In debug configuration I use the following configuration:  GDB PEMicro Interface/USB Multilink, Port/USB1-Multilink Universal Rev B (PE5655394).
I appreciate your help.
Bouba
1 解答
1,534 次查看
boubacarhoussei
I get it working. It was hardware configuration issue. I opened jumpers J521 & J522 on the TWR-KV46F150M board and it works perfectly.
在原帖中查看解决方案
1 回复
1,535 次查看
boubacarhoussei
