Changing target MCU in KDS
1,874 次查看
srinivasa_raow
I am working on Kinetis bootloader and I am porting project from MK64F12 to my target processor i.e) MK22FN1M0AVLQ12
Under section 10.3.4 of Kinetis Bootloader v2.0.0 Reference Manual explains changing the target MCU in IAR IDE.
Changing the target processor in IAR IDE is simple and straight forward and it is explained in this document.  But I am working on Kinetis Design Studio 3 IDE (KDS) and there is no option to change the target processor in KDS under Project->Properties.
How to we change target MCU in KDS?
If I go to File->New->Processor Expert Project->Project Name->Boards/Processors
Here I can select Processor for new project.  Can I change the target MCU for the existing project in KDS?
Srinivasa
1,634 次查看
Hello Srinivasa,
It seems only the project with Processor Expert can change target on KDS:
Switching the Microcontroller Package, Device and Family | MCU on Eclipse
If your project is bardboard , maybe you can create a new project ,then copy the applicaiton
files into it .
Alice
