C++ global object constructors not being called.
2,061件の閲覧回数
mike1974
Using KDS 2.0.0 and it appears as though the constructors for my global objects in C++ are not being called.  Presumably, this should happen at startup sometime before main().  I set the breakpoints in the constructors but they never get hit.
Anyone encounter this issue before?
Mike
1,841件の閲覧回数
BlackNight
1,842件の閲覧回数
BlackNight
1,841件の閲覧回数
mike1974
That fixed it thank you Erich
