Build failure: make: ../makefile.targets: Field 'stem' not cached: makefile.targets
3,613 次查看
walter_wang
I was using KDS3.1 and KSDK 1.2 with PE without problem when making build for project Test_K22F. But couple of days ago I installed New Kinetis SDK 2.x Project Wizard and KSDK 2.0 package, then build error comes out when building the same project:
I'm not very familiar with gnu make tool, so just try to search the error in Internet search engine but still no help...
Does anybody get any advice?
7 回复数
3,333 次查看
walter_wang
Hi Alice,
I knew finally the root cause, it looks very weird... Just FYI.
I pasted a .xlsx file in KDS project explorer so I can open it together with my codes in the same window, and this file may cause the issue. After I delete it, build is successful. I've repeated paste/delete actions for a few times and every times the same behavior.
I don't know why a .xlsx may cause this build issue and don't plan to deep dive into it. Just tell my finding.
Walter.
3,333 次查看
OK, thank you !
Alice
3,333 次查看
walter_wang
Hi Alice,
See attached file for the exported project. I don't have other previous projects to check this problem on this PC.
Thanks.
3,333 次查看
Hello ,
I have test your project on my side , after build , it have no error, i also install the KSDK2.0 Project Wizard.
I recommend you create one simple project , the have a try .
Alice
3,333 次查看
walter_wang
Hi Alice,
Thanks anyway, I'll try on new projects.
Walter
3,333 次查看
Hi Walter,
First you create one simple project with Processor Expert , then check whether it can work well ,
if  the simple project still have error, maybe the KDS builder have some problem.
Alice
3,333 次查看
Hello  Wang,
Could you please send your project to me , i can test it on my side.
And what about other old Project , when you now build it , does it can work well ?
Alice
