BitsIO component is only for one port, for example portA. if your dataBus contains other port, for example PortC, we can't implement the data bus with one BitsIO component. we need use additional BitsIO component for it. or use BitIO for one pin of each.
then you make your own dataBus function to combine those different together.
does this answer your question?
Zhang Jun
