serial Bootloader for K32L2B31VFM0A
Nikunj
i want to upgrade my application firmware using UART bootloader.
can you suggest the required document and example code?
Nikunj
HELLO
I want to initiate a firmware upgrade from the application, so I want to start the bootloader (KBOOT 2) from the application and keep it running. I didn't find this option in the bootloader. Do I have to program it myself? Can you recommend how to do it?
Nikunj
HELLO
