K32L2B Target not found issue using PE Microlink
Girish
I'm using K32L2B31VFT0A MCU. When I try to program the controller using PE Microlink, I'm getting "Target Not found" as shown in below image.
One more issue I'm facing in another board using using same MCU is that MCU is entering in secure mode and no matter what I do its not coming out of it.
I'm using MCUXpresso config tools to generate the code.
