ADC conversion rate range for low power configuration
1,279件の閲覧回数
matl
I am using a K32L2Ax Microcontroller. Table 34 in the datasheet https://www.nxp.com/docs/en/data-sheet/K32L2Ax.pdf states the ADC conversion clock frequency range for "<13 + 16 bit mode" operations. Where can I find the spec for the frequency ranges for low power configuration CFC1[ADLPC] or high speed mode CFG2[ADHSC]? Looks like this info is missing.
Thanks.
0 返答(返信)
