Temperature cycling details
Nivedha
Hi Team,
We need the temperature cycling test details or report of CBTL02043ABQ
The detail like for how many cycles the component has been tested from -ve to +ve temperature cycles to get qualified.
Thank You
JozefKozon
Hi Nivedha,
please find attached PQIP document where temperature cycling test details are described. Section 4.2.
With Best Regards,
Jozef
JozefKozon
Hi Nivedha,
With Best Regards,
Jozef
%3CLINGO-SUB%20id%3D%22lingo-sub-2350505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETemperature%20cycling%20details%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Team%2C%3C%2FP%3E%3CP%3EWe%20need%20the%20temperature%20cycling%20test%20details%20or%20report%20of%26nbsp%3BCBTL02043ABQ%3C%2FP%3E%3CP%3EThe%20detail%20like%20for%20how%20many%20cycles%20the%20component%20has%20been%20tested%20from%20-ve%20to%20%2Bve%20temperature%20cycles%20to%20get%20qualified.%3C%2FP%3E%3CP%3EThank%20You%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Temperature%20cycling%20details%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Nivedha%2C%3C%2FP%3E%0A%3CP%3Eplease%20find%20attached%20PQIP%20document%20where%20temperature%20cycling%20test%20details%20are%20described.%20Section%204.2.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EWith%20Best%20Regards%2C%3C%2FP%3E%0A%3CP%3EJozef%3C%2FP%3E%3C%2FLINGO-BODY%3E
