IRQ on SC16IS740
IRQ on SC16IS740
BENTON
I can't find this in the datasheet. . .
What clears the IRQ pin on the 16S740?
If I am sending the last of a sequence of characters (FIFO disabled) how should I respond to the "Transmit register empty" interrupt?
ErikaC
To clear the interrupt and deactivate the IRQ pin, it is necessary to read the IIR, which also clears the specific interrupt.
