IRQ on SC16IS740
IRQ on SC16IS740
1,041 次查看
BENTON
I can't find this in the datasheet. . .
What clears the IRQ pin on the 16S740?
If I am sending the last of a sequence of characters (FIFO disabled) how should I respond to the "Transmit register empty" interrupt?
1,030 次查看
ErikaC
To clear the interrupt and deactivate the IRQ pin, it is necessary to read the IIR, which also clears the specific interrupt.
