Balancing on bma7418
894件の閲覧回数
blo
I am trying to configure balancing on BMA7418 using the provided CDD. The overall goal is for the application SW to request which (if any) cells should be discharged at any given time and for the CDD to configure the BCC accordingly.
In tresos I have enabled the "Enable BAL feature" and am now looking at the api of the CDD. We have Bcc_D1xx_BAL_SetGlobalConfiguration and Bcc_D1xx_BAL_SetChannelConfiguration.
I assume we want to enable all balancing in Bcc_D1xx_BAL_SetGlobalConfiguration one time and then at runtime configure the actual balancing using Bcc_D1xx_BAL_SetChannelConfiguration, is this correct?
Bcc_D1xx_BAL_SetGlobalConfiguration takes struct Bcc_D1xx_BalConfigurationType. Should we use FullEvenBal/FullOddBal or BalChannels(0/1)En? What is the point of TimerBasedBal, PreBalTimer and GlobalBalTimer?
Bcc_D1xx_BAL_SetChannelConfiguration takes struct Bcc_D1xx_BalChannelConfigurationType, Do I just give the channel id(not bitmasking possible?) and the pwm? what is the resolution of the timer?
If there is sample code for balancing available that would be great, I could not find it in the delivered CDD
  • SPI
タグ(1)
2 返答(返信)
735件の閲覧回数
guoweisun
HI
For example you can select the time based CB function to test, you can download RM00304 and read it from page 30 which has detail configure steps, also has explain about
TimerBasedBal、PreBalTimer GlobalBalTimer
Because of this documentation is confidential so I can't reveal too much
558件の閲覧回数
db16122
Welcome to join the event at Wed, Jun 24, 2026 and ask your question
How to Safely Charge a Battery Faster with NXP's eisBMS Chipset: The Excitation! | Part 4
For setting detail about EIS function, please refer to UG10341 EIS enablement package quick start guide
%3CLINGO-SUB%20id%3D%22lingo-sub-2373153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ebma7418%E3%81%AE%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E8%AA%BF%E6%95%B4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2373153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9FCDD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81BMA7418%E3%81%AE%E8%B2%A0%E8%8D%B7%E5%88%86%E6%95%A3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%85%A8%E4%BD%93%E7%9A%84%E3%81%AA%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E4%BB%BB%E6%84%8F%E3%81%AE%E6%99%82%E7%82%B9%E3%81%A7%E3%81%A9%E3%81%AE%E3%82%BB%E3%83%AB%E3%82%92%E6%94%BE%E9%9B%BB%E3%81%99%E3%81%B9%E3%81%8D%E3%81%8B%EF%BC%88%E3%82%82%E3%81%97%E3%81%82%E3%82%8C%E3%81%B0%EF%BC%89%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%80%81CDD%E3%81%8C%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6BCC%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%82%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%3ETresos%E3%81%A7%E3%81%AF%E3%80%8CBAL%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%80%8D%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%80%81%E7%8F%BE%E5%9C%A8CDD%E3%81%AEAPI%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82Bcc_D1xx_BAL_SetGlobalConfiguration%20%E3%81%A8%20Bcc_D1xx_BAL_SetChannelConfiguration%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EBcc_D1xx_BAL_SetGlobalConfiguration%E3%81%A7%E4%B8%80%E5%BA%A6%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%80%81%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%ABBcc_D1xx_BAL_SetChannelConfiguration%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%80%81%E3%81%A8%E3%81%84%E3%81%86%E7%90%86%E8%A7%A3%E3%81%A7%E3%82%88%E3%82%8D%E3%81%97%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3EBcc_D1xx_BAL_SetGlobalConfiguration%20%E3%81%AF%E3%80%81struct%20Bcc_D1xx_BalConfigurationType%20%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82FullEvenBal%2FFullOddBal%20%E3%81%BE%E3%81%9F%E3%81%AF%20BalChannels(0%2F1)En%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3FTimerBasedBal%E3%80%81PreBalTimer%E3%80%81GlobalBalTimer%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3EBcc_D1xx_BAL_SetChannelConfiguration%20%E3%81%AF%20struct%20Bcc_D1xx_BalChannelConfigurationType%20%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20ID%20%E3%82%92%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E6%B8%A1%E3%81%9B%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%20(%E3%83%93%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B)%EF%BC%9FPWM%E3%81%AF%E3%81%A9%E3%81%86%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%AE%E5%88%86%E8%A7%A3%E8%83%BD%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%8F%E3%82%89%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%83%90%E3%83%A9%E3%83%B3%E3%82%B9%E8%AA%BF%E6%95%B4%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E5%A4%A7%E5%A4%89%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%98%E5%B1%9E%E3%81%AECDD%E3%81%AB%E3%81%AF%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2373153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESPI%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2377232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Balancing%20on%20bma7418%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2377232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%E6%99%82%E9%96%93%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AECB%E6%A9%9F%E8%83%BD%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82RM00304%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%80%81%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%A8%AD%E5%AE%9A%E6%89%8B%E9%A0%86%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B30%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%8B%E3%82%89%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%3CCODE%20translate%3D%22no%22%3ETimerBasedBal%3C%2FCODE%3E%E3%80%81%3CCODE%20translate%3D%22no%22%3EPreBalTimer%3C%2FCODE%3E%20%3CCODE%20translate%3D%22no%22%3EGlobalBalTimer%3C%2FCODE%3E%3C%2FDIV%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1780640036006.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1780640036006.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1780640036006.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F387987iA609850A96BF5324%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1780640036006.png%22%20alt%3D%22guoweisun_0-1780640036006.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E6%A9%9F%E5%AF%86%E6%83%85%E5%A0%B1%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%81%82%E3%81%BE%E3%82%8A%E5%A4%9A%E3%81%8F%E3%81%AF%E6%98%8E%E3%81%8B%E3%81%9B%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2381655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Balancing%20on%20bma7418%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2381655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E2026%E5%B9%B46%E6%9C%8824%E6%97%A5%EF%BC%88%E6%B0%B4%EF%BC%89%E3%81%AE%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AB%E3%81%94%E5%8F%82%E5%8A%A0%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%94%E8%B3%AA%E5%95%8F%E3%82%92%E3%81%8A%E5%AF%84%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENXP%E3%81%AEeisBMS%E3%83%81%E3%83%83%E3%83%97%E3%82%BB%E3%83%83%E3%83%88%E3%81%A7%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E3%82%92%E5%AE%89%E5%85%A8%E3%81%8B%E3%81%A4%E9%AB%98%E9%80%9F%E3%81%AB%E5%85%85%E9%9B%BB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%EF%BC%9A%E8%88%88%E5%A5%AE%EF%BC%81%EF%BD%9C%E3%83%91%E3%83%BC%E3%83%884%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EEIS%E6%A9%9F%E8%83%BD%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81UG10341%20EIS%E6%9C%89%E5%8A%B9%E5%8C%96%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
