width of user code window cannot be changed?
PragmaLab
since I'm using the Code section when defining events quite often, it bothers me that the width of this window cannot be altered? This way it is quite inconvenient to enter/change text in there.
Do I overlook something here? As far as I know, this window cannot be resized, nor detached/docked in any way. If so, pls let me know
If not:  would be nice if this could be fixed in the next release?
Rob
zhenhualuo
Hi @PragmaLab
Thanks for your feedback, the code editor can be resized in next GUI Guider release.
Zhenhua
RaRo
Hello @PragmaLab,
Unfortunately, as you mention, the window of Code can not be resized, nor modify in any way.
Thanks for pointing out the issue. We will let the team in charge to know about this, hopefully in next releases windows can be resized, and/or detached/docked.
Finally, as a recommendation, you could try writing the code first in other IDE, and then copy and paste it in the Code Window.
Best regards, Raul.
