Why widget's name is not allowed to be same across different screens in IDE
zzz4web
Widget's name should be unique only in the SAME screen, right?
But the IDE was not allow to have widgets with same name in DIFFERENT screen.
And if I copy a screen, the widgets name inside the cloned screen can be kept consistent.
It will be better to allow same name widget across screen for shorter object name in c codes
ZhangJennie
Hi zzz4web
This is a known issue. It will be fixed in next release GUIGuider_GA_v1.6.0.
Thanks for bringing the problem to our attention.
Jun Zhang
