Why is The device not connected
已解决
跳至解决方案
2,244 次查看
dsd
The gui guider fails to connect to the LPC5506.via jlink
1 解答
2,221 次查看
nxa22510
Could I double confirm with as you what's the board you're using? If the board was LPC5506 you used, it's not supported and we didn't test in the previous releases. But the board of LPC55S06 supported. You will find the list of  supported boards in the documents and also could see the detailed supported boards when you creating the project.
在原帖中查看解决方案
1 回复
2,222 次查看
nxa22510
