Version 2 issues: C code generation, preview
1,115 次查看
poldo
Hi!
I started testing GUI Guider version 2, and I found a couple of issues (starting with an empty template, Windows simulator).
I started defining the content of the top layer putting an image button, creating an event handler to switch state when the button is long pressed.
The generated the code has some errors, like:
gg_event_layer_top.c:
  static void lv_layer_top()_event_handler(lv_event_t * e) {
void gg_event_init_layer_top(gg_ui_t * ui
  lv_obj_add_event_cb(ui->layer_top.lv_layer_top(),  lv_layer_top()_event_handler, LV_EVENT_ALL, ui);
(parenthesis create a parsing error)
Manually removing the parenthesis, the error below is generated:
.../generated/events/gg_event_layer_top.c:59:38: error: 'gg_layer_top_t' has no member named 'lv_layer_top'
(gg_layer_top_t definition doesn't include that member)
Am I missing some definition to make a correct generation of those functions?
8 回复数
839 次查看
poldo
Hi @Harry_Zhang .
The issue is when you create objects on the top layr. I'm attaching my file for your review and test.
710 次查看
meibao
This is a bug, and the fix is simple. Find your guiguider file and open it in text mode. Locate the event_list, remove any extra content, and then use the guider to reload the project. The generated code will return to normal.
248 次查看
poldo
Thank you, @meibao : I'll try that.
725 次查看
Harry_Zhang
Hi @poldo
Thanks for your project, we have reproduced this issue.
This is a bug.
We will fix it in the next version.
Thank you for your understanding.
Harry
714 次查看
poldo
Thank you, @Harry_Zhang .
Is there a workaround that could be used while waiting for the update?
1,031 次查看
poldo
Hi @Harry_Zhang , thank you for your reply.
This is what I did:
- On layer_top (clickable flag added, is this necessary?) I created a container for my buttons (no clickable flag added)
- Inside the container I created an image button (clickable flag added)
- I attached the event "Long Pressed" to the button
Generated code contains the syntax errors above.
// In gg_event_layer_top.c
    gg_ui_t * ui = lv_event_get_user_data(e);
    lv_event_code_t code = lv_event_get_code(e);
    switch(code) {
        default:
            break;
void gg_event_init_layer_top(gg_ui_t * ui)
    lv_obj_add_event_cb(ui->layer_top.Keypad_btnEnable, Keypad_btnEnable_event_handler, LV_EVENT_ALL, ui);
Removing the parenthesis the syntax error is about the member lv_layer_top not existing:
// In custom.h
typedef struct {
    lv_obj_t * Keypad;
    lv_obj_t * Keypad_btnEnable;
} gg_layer_top_t;
Poldo
1,002 次查看
Harry_Zhang
Hi @poldo
I tried to reproduce this issue.
The generated code is correct.
May I ask what I missed?
Harry
1,057 次查看
Harry_Zhang
Hi @poldo
May i ask how can i reproduce this issue?
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2393831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%89%88%E6%9C%AC%202%20%E9%97%AE%E9%A2%98%EF%BC%9AC%20%E4%BB%A3%E7%A0%81%E7%94%9F%E6%88%90%E3%80%81%E9%A2%84%E8%A7%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2393831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%BC%80%E5%A7%8B%E6%B5%8B%E8%AF%95%20GUI%20Guider%20%E7%89%88%E6%9C%AC%202%EF%BC%8C%E5%8F%91%E7%8E%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%EF%BC%88%E4%BB%8E%E7%A9%BA%E7%99%BD%E6%A8%A1%E6%9D%BF%E5%92%8C%20Windows%20%E6%A8%A1%E6%8B%9F%E5%99%A8%E5%BC%80%E5%A7%8B%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%BC%80%E5%A7%8B%E5%AE%9A%E4%B9%89%E9%A1%B6%E5%B1%82%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%8C%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%B8%80%E4%B8%AA%E5%9B%BE%E5%83%8F%E6%8C%89%E9%92%AE%EF%BC%8C%E5%B9%B6%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E4%BA%8B%E4%BB%B6%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%9C%A8%E9%95%BF%E6%8C%89%E6%8C%89%E9%92%AE%E6%97%B6%E5%88%87%E6%8D%A2%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Egg_event_layer_top.c%EF%BC%9A%3CBR%20%2F%3E%3C%2FFONT%3E%20%3CSPAN%3Estatic%20void%20lv_layer_top()_event_handler(lv_event_t%20*%20e)%20%7B%3CBR%20%2F%3E%20...%3CBR%20%2F%3E%3C%2FSPAN%3E%20%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3Egg_event_init_layer_top%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Egg_ui_t%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3Eui%3C%2FSPAN%3E%3CSPAN%3E%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3Elv_obj_add_event_cb(ui-%26gt%3Blayer_top.lv_layer_top()%2C%20lv_layer_top()_event_handler%2C%20LV_EVENT_ALL%2C%20ui)%3B%3C%2FFONT%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CP%3E%EF%BC%88%E6%8B%AC%E5%8F%B7%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%A7%A3%E6%9E%90%E9%94%99%E8%AF%AF%EF%BC%89%3C%2FP%3E%3CP%3E%E6%89%8B%E5%8A%A8%E5%88%A0%E9%99%A4%E6%8B%AC%E5%8F%B7%E5%90%8E%EF%BC%8C%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3E...%2Fgenerated%2Fevents%2Fgg_event_layer_top.c%3A59%3A38%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A'gg_layer_top_t'%20%E6%B2%A1%E6%9C%89%E5%90%8D%E4%B8%BA%20'lv_layer_top'%20%E7%9A%84%E6%88%90%E5%91%98%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%EF%BC%88gg_layer_top_t%20%E5%AE%9A%E4%B9%89%E4%B8%AD%E4%B8%8D%E5%8C%85%E5%90%AB%E8%AF%A5%E6%88%90%E5%91%98%EF%BC%89%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%E5%90%A6%E9%81%97%E6%BC%8F%E4%BA%86%E6%9F%90%E4%BA%9B%E5%AE%9A%E4%B9%89%EF%BC%8C%E5%AF%BC%E8%87%B4%E6%97%A0%E6%B3%95%E6%AD%A3%E7%A1%AE%E7%94%9F%E6%88%90%E8%BF%99%E4%BA%9B%E5%87%BD%E6%95%B0%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259294%22%20target%3D%22_blank%22%3E%40poldo%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E9%97%AE%E5%A6%82%E4%BD%95%E9%87%8D%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1783917409079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392057i73C2A06D3F68C4FA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1783917409079.png%22%20alt%3D%22Harry_Zhang_0-1783917409079.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1783917409079.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E9%87%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%20%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%99%E6%A0%B7%E5%81%9A%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CP%3E-%20%E5%9C%A8%20layer_top%20%E4%B8%8A%EF%BC%88%E6%B7%BB%E5%8A%A0%E4%BA%86%E5%8F%AF%E7%82%B9%E5%87%BB%E6%A0%87%E5%BF%97%EF%BC%8C%E8%BF%99%E6%98%AF%E5%BF%85%E8%A6%81%E7%9A%84%E5%90%97%EF%BC%9F%EF%BC%89%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E7%94%A8%E4%BA%8E%E6%94%BE%E7%BD%AE%E6%8C%89%E9%92%AE%E7%9A%84%E5%AE%B9%E5%99%A8%EF%BC%88%E6%B2%A1%E6%9C%89%E6%B7%BB%E5%8A%A0%E5%8F%AF%E7%82%B9%E5%87%BB%E6%A0%87%E5%BF%97%EF%BC%89%E3%80%82%3CBR%20%2F%3E%20%3CSPAN%3E-%20%E6%88%91%E5%9C%A8%E5%AE%B9%E5%99%A8%E5%86%85%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E5%9B%BE%E5%83%8F%E6%8C%89%E9%92%AE%EF%BC%88%E6%B7%BB%E5%8A%A0%E4%BA%86%E5%8F%AF%E7%82%B9%E5%87%BB%E7%9A%84%E6%A0%87%E5%BF%97%EF%BC%89%3CBR%20%2F%3E%E6%88%91%E5%B7%B2%E5%B0%86%E2%80%9C%E9%95%BF%E6%8C%89%E2%80%9D%E4%BA%8B%E4%BB%B6%E9%99%84%E5%8A%A0%E5%88%B0%E6%8C%89%E9%92%AE%E4%B8%8A%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22poldo_0-1784023768341.png%22%20style%3D%22width%3A%20885px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392226iBFF783192D285B94%2Fimage-dimensions%2F885x521%3Fv%3Dv2%22%20width%3D%22885%22%20height%3D%22521%22%20role%3D%22button%22%20title%3D%22poldo_0-1784023768341.png%22%20alt%3D%22poldo_0-1784023768341.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Epoldo_0-1784023768341.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E5%8C%85%E5%90%AB%E4%B8%8A%E8%BF%B0%E8%AF%AD%E6%B3%95%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%2F%20In%20gg_event_layer_top.c%0Astatic%20void%20lv_layer_top()_event_handler(lv_event_t%20*%20e)%0A%7B%0A%20%20%20%20gg_ui_t%20*%20ui%20%3D%20lv_event_get_user_data(e)%3B%0A%0A%20%20%20%20lv_event_code_t%20code%20%3D%20lv_event_get_code(e)%3B%0A%0A%20%20%20%20switch(code)%20%7B%0A%0A%20%20%20%20%20%20%20%20default%3A%0A%20%20%20%20%20%20%20%20%20%20%20%20break%3B%0A%20%20%20%20%7D%0A%7D%0A%0Avoid%20gg_event_init_layer_top(gg_ui_t%20*%20ui)%0A%7B%0A%20%20%20%20lv_obj_add_event_cb(ui-%26gt%3Blayer_top.lv_layer_top()%2C%20lv_layer_top()_event_handler%2C%20LV_EVENT_ALL%2C%20ui)%3B%0A%20%20%20%20lv_obj_add_event_cb(ui-%26gt%3Blayer_top.Keypad_btnEnable%2C%20Keypad_btnEnable_event_handler%2C%20LV_EVENT_ALL%2C%20ui)%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%8E%BB%E6%8E%89%E6%8B%AC%E5%8F%B7%E5%90%8E%EF%BC%8C%E8%AF%AD%E6%B3%95%E9%94%99%E8%AF%AF%E6%98%AF%E5%85%B3%E4%BA%8E%E6%88%90%E5%91%98%20lv_layer_top%20%E4%B8%8D%E5%AD%98%E5%9C%A8%E7%9A%84%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%2F%20In%20custom.h%0Atypedef%20struct%20%7B%0A%0A%20%20%20%20lv_obj_t%20*%20Keypad%3B%0A%20%20%20%20lv_obj_t%20*%20Keypad_btnEnable%3B%0A%7D%20gg_layer_top_t%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EBR%3C%2FP%3E%3CP%3E%E6%B3%A2%E5%B0%94%E5%A4%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259294%22%20target%3D%22_blank%22%3E%40poldo%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E9%87%8D%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1784102463813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392338i96865926C7C6EACF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1784102463813.png%22%20alt%3D%22Harry_Zhang_0-1784102463813.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1784102463813.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1784102495298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392339i84E70EF53A84FFC9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_1-1784102495298.png%22%20alt%3D%22Harry_Zhang_1-1784102495298.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_1-1784102495298.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E9%97%AE%E6%88%91%E9%94%99%E8%BF%87%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E9%87%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2397751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%20%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E9%A1%B6%E5%B1%82%E5%88%9B%E5%BB%BA%E5%AF%B9%E8%B1%A1%E6%97%B6%E3%80%82%E6%88%91%E9%99%84%E4%B8%8A%E6%96%87%E4%BB%B6%E4%BE%9B%E6%82%A8%E5%AE%A1%E9%98%85%E5%92%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E6%BC%8F%E6%B4%9E%EF%BC%8C%E4%BF%AE%E5%A4%8D%E8%B5%B7%E6%9D%A5%E5%BE%88%E7%AE%80%E5%8D%95%E3%80%82%E6%89%BE%E5%88%B0%E4%BD%A0%E7%9A%84%20guiguider%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E4%BB%A5%E6%96%87%E6%9C%AC%E6%A8%A1%E5%BC%8F%E6%89%93%E5%BC%80%E5%AE%83%E3%80%82%E6%89%BE%E5%88%B0%20event_list%EF%BC%8C%E5%88%A0%E9%99%A4%E4%BB%BB%E4%BD%95%E5%A4%9A%E4%BD%99%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BD%BF%E7%94%A8%E6%8C%87%E5%8D%97%E9%87%8D%E6%96%B0%E5%8A%A0%E8%BD%BD%E9%A1%B9%E7%9B%AE%E3%80%82%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E5%B0%86%E6%81%A2%E5%A4%8D%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399022%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259294%22%20target%3D%22_blank%22%3E%40poldo%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E9%87%8D%E7%8E%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%AA%E6%BC%8F%E6%B4%9E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%86%E5%9C%A8%E4%B8%8B%E4%B8%80%E4%B8%AA%E7%89%88%E6%9C%AC%E4%B8%AD%E4%BF%AE%E5%A4%8D%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%90%86%E8%A7%A3%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E9%87%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%20%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E7%AD%89%E5%BE%85%E6%9B%B4%E6%96%B0%E6%9C%9F%E9%97%B4%EF%BC%8C%E6%9C%89%E6%B2%A1%E6%9C%89%E4%BB%80%E4%B9%88%E5%8F%98%E9%80%9A%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2410697%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Version%202%20issues%3A%20C%20code%20generation%2C%20preview%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2410697%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265038%22%20target%3D%22_blank%22%3E%40meibao%3C%2FA%3E%20%EF%BC%9A%E6%88%91%E4%BC%9A%E8%AF%95%E8%AF%95%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
