Unable to Run GUI Guider 1.10.0 DemoAPP on MIMXRT1170-EVKB
NXTyam
Hi NXP.
I am trying to run the ButtonCounter demo application using the following setup:
  • MIMXRT1170-EVKB + RK055AHD091
  • GUI Guider 1.10.0-GA
  • MCUXpresso 25.6.136
  • LVGL 9.2.1 / LVGL 8.3.10
  • SDK 25.09.00
However, even after executing Build & Run Target, the application does not work as expected.
Am I doing something wrong? I would greatly appreciate any advice or guidance.
For reference, here is the toolchain output:
Checking device connection...
Cleaning generated screen files...
Generating C code...
✓ Code generation completed!
Run CMake To Generate Makefile
-- TOOLCHAIN_DIR: C:/nxp/MCUXpressoIDE_25.6.136/ide/tools
-- BUILD_TYPE: flexspi_nor_sdram_release
-- The C compiler identification is GNU 14.2.1
-- The CXX compiler identification is GNU 14.2.1
-- The ASM compiler identification is GNU
Thank you in advance for your support!
Tags (2)
NXTyam
Hi, @mayliu1
I have identified the root cause of the problem.
On the MIMXRT1170-EVKB board, pins 5 and 6 of the SDRAM (U25) were shorted, which prevented proper programming.
After removing the solder that caused the short and reprogramming the board, everything is now working correctly.
Thank you for your advice and support!
mayliu1
Hi @NXTyam ,
Thank you so much for your interest in our products and for using our community.
Please check your MIMXRT1170-EVKB development board settings:
1: Is the RK055AHD091 screen correctly connected to the J48 of the MIMXRT1170-EVKB development board?
2: Is 5V power connected to MIMXRT1170-EVKB J43, and is J38 set to 1-2?
Have you successfully run GUI Guider project before? I suggest confirming your hardware development environment and then trying to run the simplest demo again.
Wish it helps you.
Best Regards
MayLiu
NXTyam
Hi, @mayliu1
Thank you for your reply.
As shown in the image below, the connections appear to be correct, and J48, J43, and J38 are all properly configured.
I have never been able to successfully run a GUI Guider project.
None of the demo applications work as expected; they all result in the same issue.
mayliu1
Thanks  for your solution sharing.
If you meet any issue in the future, welcome to create the new question post.
NXTyam
Hi, @mayliu1
%3CLINGO-SUB%20id%3D%22lingo-sub-2188912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUnable%20to%20Run%20GUI%20Guider%201.10.0%20DemoAPP%20on%20MIMXRT1170-EVKB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2188912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%20NXP.%3C%2FSPAN%3E%3CBR%20%2F%3EI%20am%20trying%20to%20run%20the%20ButtonCounter%20demo%20application%20using%20the%20following%20setup%3A%3C%2FP%3E%3CUL%3E%3CLI%3EMIMXRT1170-EVKB%20%2B%20RK055AHD091%3C%2FLI%3E%3CLI%3EGUI%20Guider%201.10.0-GA%3C%2FLI%3E%3CLI%3EMCUXpresso%2025.6.136%3C%2FLI%3E%3CLI%3ELVGL%209.2.1%20%2F%20LVGL%208.3.10%3C%2FLI%3E%3CLI%3ESDK%2025.09.00%3C%2FLI%3E%3C%2FUL%3E%3CP%3EHowever%2C%20even%20after%20executing%20Build%20%26amp%3B%20Run%20Target%2C%20the%20application%20does%20not%20work%20as%20expected.%3CBR%20%2F%3EAm%20I%20doing%20something%20wrong%3F%20I%20would%20greatly%20appreciate%20any%20advice%20or%20guidance.%3CBR%20%2F%3EFor%20reference%2C%20here%20is%20the%20toolchain%20output%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-javascript%22%3E%3CCODE%3EChecking%20device%20connection...%0ACleaning%20generated%20screen%20files...%0AGenerating%20C%20code...%0A%E2%9C%93%20Code%20generation%20completed!%0ARun%20CMake%20To%20Generate%20Makefile%0A--%20TOOLCHAIN_DIR%3A%20C%3A%2Fnxp%2FMCUXpressoIDE_25.6.136%2Fide%2Ftools%0A--%20BUILD_TYPE%3A%20flexspi_nor_sdram_release%0A--%20TOOLCHAIN_DIR%3A%20C%3A%2Fnxp%2FMCUXpressoIDE_25.6.136%2Fide%2Ftools%0A--%20BUILD_TYPE%3A%20flexspi_nor_sdram_release%0A--%20The%20C%20compiler%20identification%20is%20GNU%2014.2.1%0A--%20The%20CXX%20compiler%20identification%20is%20GNU%2014.2.1%0A--%20The%20ASM%20compiler%20identification%20is%20GNU%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EThank%20you%20in%20advance%20for%20your%20support!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Run%20GUI%20Guider%201.10.0%20DemoAPP%20on%20MIMXRT1170-EVKB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%26nbsp%3B%20for%20your%20solution%20sharing.%3C%2FP%3E%0A%3CP%3EIf%20you%20meet%20any%20issue%20in%20the%20future%2C%20welcome%20to%20create%20the%20new%20question%20post.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2190462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Run%20GUI%20Guider%201.10.0%20DemoAPP%20on%20MIMXRT1170-EVKB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2190462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239163%22%20target%3D%22_blank%22%3E%40mayliu1%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EI%20have%20identified%20the%20root%20cause%20of%20the%20problem.%3CBR%20%2F%3EOn%20the%20MIMXRT1170-EVKB%20board%2C%20pins%205%20and%206%20of%20the%20SDRAM%20(U25)%20were%20shorted%2C%20which%20prevented%20proper%20programming.%3C%2FP%3E%3CP%3EAfter%20removing%20the%20solder%20that%20caused%20the%20short%20and%20reprogramming%20the%20board%2C%20everything%20is%20now%20working%20correctly.%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20advice%20and%20support!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Run%20GUI%20Guider%201.10.0%20DemoAPP%20on%20MIMXRT1170-EVKB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239163%22%20target%3D%22_blank%22%3E%40mayliu1%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20reply.%3CBR%20%2F%3EAs%20shown%20in%20the%20image%20below%2C%20the%20connections%20appear%20to%20be%20correct%2C%20and%20J48%2C%20J43%2C%20and%20J38%20are%20all%20properly%20configured.%3C%2FP%3E%3CP%3EI%20have%20never%20been%20able%20to%20successfully%20run%20a%20GUI%20Guider%20project.%3CBR%20%2F%3ENone%20of%20the%20demo%20applications%20work%20as%20expected%3B%20they%20all%20result%20in%20the%20same%20issue.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189130%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20Run%20GUI%20Guider%201.10.0%20DemoAPP%20on%20MIMXRT1170-EVKB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189130%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255952%22%20target%3D%22_blank%22%3E%40NXTyam%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20so%20much%20for%20your%20interest%20in%20our%20products%20and%20for%20using%20our%20community.%3C%2FP%3E%0A%3CP%3EPlease%20check%20your%20MIMXRT1170-EVKB%20development%20board%20settings%3A%3C%2FP%3E%0A%3CP%3E1%3A%20Is%20the%20RK055AHD091%20screen%20correctly%20connected%20to%20the%20J48%20of%20the%20MIMXRT1170-EVKB%20development%20board%3F%3CBR%20%2F%3E2%3A%20Is%205V%20power%20connected%20to%20MIMXRT1170-EVKB%20J43%2C%20and%20is%20J38%20set%20to%201-2%3F%3C%2FP%3E%0A%3CP%3EHave%20you%20successfully%20run%20GUI%20Guider%20project%20before%3F%20I%20suggest%20confirming%20your%20hardware%20development%20environment%20and%20then%20trying%20to%20run%20the%20simplest%20demo%20again.%3C%2FP%3E%0A%3CP%3EWish%20it%20helps%20you.%3CBR%20%2F%3EIf%20you%20still%20have%20question%20about%20it%2C%20please%20kindly%20let%20me%20know.%3C%2FP%3E%0A%3CP%3EBest%20Regards%3CBR%20%2F%3EMayLiu%3C%2FP%3E%3C%2FLINGO-BODY%3E
