Hello Community.
I'm Currently working on a small project with the MIMXRT1060-EVKB with a RK043FN66HS-CTG LCD Display.
I'm trying to use the Gui Guider to build a mock-up for a controll in Portrait mode but learned that LVGL does not support Portrait mode for MIMXRT1060-EVKB:https://community.nxp.com/t5/i-MX-Processors/I-MX-1060-SDK-lvgl-guider-rotation-display/m-p/1613926If the screen can't be rotated i thought i might be possible to rotate Label's, Textboxes or Containers to display values in a pseudo Portrait mode but wasn't able to find anything regarding this matter.
Any tips or help would be appreciated.
With best regards,JayPM
Hello, recently I found this information, I suggest you can try to modify the form of the button and text, maybe can help to modify your code.
Quick overview — LVGL documentation
Bert regards,Pavel
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you.
Best regards,Pavel
