When I add a new item to the list and I open the "Event Setting" window, there is no way to add event to this new item. I can only see previously defined events.
I send you a video on your other thread, I think after check that you can also can solve this issue, is still no , you can contact me without any hesitate, thanks.
- Add new item to the list - Add an event to this item - Delete the item - ! The event is not deleted with the item and the compiler is looking for this item, hence error in compilation.
