I can't add an event to a list item
1,437 次查看
bosnian_beast
When I add a new item to the list and I open the "Event Setting" window, there is no way to add event to this new item. I can only see previously defined events.
1,416 次查看
Hello @bosnian_beast
I send you a video on your other thread, I think after check that you can also can solve this issue, is still no , you can contact me without any hesitate, thanks.
Alice
1,397 次查看
bosnian_beast
Now the issue is that when I:
- Add new item to the list
- Add an event to this item
- Delete the item
- ! The event is not deleted with the item and the compiler is looking for this item, hence error in compilation.
1,381 次查看
You think the event need deleted when delete item ? I will forward your suggestion to development team.
I think the event custom code is add manually, so usually need be removed manually.
Alice
