I can't add an event to a list item
bosnian_beast
When I add a new item to the list and I open the "Event Setting" window, there is no way to add event to this new item. I can only see previously defined events.
Hello @bosnian_beast
I send you a video on your other thread, I think after check that you can also can solve this issue, is still no , you can contact me without any hesitate, thanks.
Alice
bosnian_beast
Now the issue is that when I:
- Add new item to the list
- Add an event to this item
- Delete the item
- ! The event is not deleted with the item and the compiler is looking for this item, hence error in compilation.
You think the event need deleted when delete item ? I will forward your suggestion to development team.
I think the event custom code is add manually, so usually need be removed manually.
Alice
