How to use GUI_guider V1.2 build file system support hmi project
ソリューションへジャンプ
5,501件の閲覧回数
ClusterDesign
Dear Support:
    Recently we use GUI_Guider V1.2 building HMI project based on RT1170 EVK board. Unfortunately, i can not find the file system supporting settings on that tool. Each picture generate a .c source code. That's impossible for us to use this tool to create a project with nearly 1000 pictures in .c code. I wish to know how can i use GUI_guider to create a HMI project can split picture & font using file system to store the file in flash or eMMC not using .c files.
5,482件の閲覧回数
zhenhualuo
Currently GUI Guider doesn't support settings to load fonts and images from external storage (e.g. eMMC), this is a new feature planned in future release. LVGL library supports file system module and loading images from external storage, can you please check if the following guide could help?
https://docs.lvgl.io/7.11/overview/image.html
https://docs.lvgl.io/7.11/overview/file-system.html
Zhenhua
2 返答(返信)
5,483件の閲覧回数
zhenhualuo
Zhenhua
5,456件の閲覧回数
ClusterDesign
Hi Zhenghua:
  Thanks for your reply, i wait in hope the version GUI_Guider in future release support file system. So that can expand the tool usage in HMI products.
