GUIDER 1.7.0
关于lv_anim_set_time(&anim, duration);
在界面编缉时,线性动画时间调到10000ms就不能往上调了,
还有其它地方可以设置吗?
Hi @AndyLiang,
The GUI Guider generated code will not create a lv_anim_set_time() function with duration larger than 10000, you are correct. However, by adding custom code to a widget you should be able to add a lv_anim_set_time() function with a duration larger than 10000. Here's the link of the GUI Guider User Guide section that describes custom code attributes:
BR,
Edwin.
