GUI Guider need add widget's' hide and show option
2,297 次查看
zhaojianzhi
when I  create  same widgets at the same position, i can't identity them.
when i use another ide,such as Squareline studio, it can do this.
2,250 次查看
CarlosGarabito
The next release will be out on February, this will have some improve
2,251 次查看
CarlosGarabito
2,270 次查看
CarlosGarabito
Hi @zhaojianzhi, thanks for your comments, we will check it, and we will try to add it in our next release.
Could you provide more information?, which version of GuiGuider are you are using?
Have a good day
2,264 次查看
zhaojianzhi
Version is 1.4.1 .
