GUI Guider examples Horizontal vs Vertical
SolitoFrancesco
Hello
I noticed that if I open an example project for MIMXRT1170-EVK, the default settings seem to be for vertical display, but then all the pictures "are stretched". If instead I modify the Panel Type in a "custom" way (so I put the same panel name RK055MHD091) using width=1280 and height=720, the pictures are represented correctly as expected.
I would like to have a confirmation that this is the normal behavior or not (because to be honest I expect to get the example already working correctly in horizontal way, so my doubt is that I'm making something wrong on another setting of GUI Guider or in a HW setting of the evaluation board).
Thnak you and kind regards,
Francesco
EdwinHz
Hi @SolitoFrancesco,
Yes, this would be the method to use on versions of GUI Guider that don't have the option of 1280x720 natively.
That said, I would like to add a recommendation to make sure you are using the latest version of GUI Guider (v1.10.0).
BR,
Edwin.
EdwinHz
BR,
Edwin.
SolitoFrancesco
Thank you. To be honest it seems to be that also in GUI Guider 1.10.0 there isn't a horizontal option 720x1280. Anyway it's not a problem. Thanks for confirmation that I'm doing the correct thing.
Kind regards,
Francesco
%3CLINGO-SUB%20id%3D%22lingo-sub-2180461%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGUI%20Guider%20examples%20Horizontal%20vs%20Vertical%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180461%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%3CP%3EI%20noticed%20that%20if%20I%20open%20an%20example%20project%20for%20MIMXRT1170-EVK%2C%20the%20default%20settings%20seem%20to%20be%20for%20vertical%20display%2C%20but%20then%20all%20the%20pictures%20%22are%20stretched%22.%20If%20instead%20I%20modify%20the%20Panel%20Type%20in%20a%20%22custom%22%20way%20(so%20I%20put%20the%20same%20panel%20name%20RK055MHD091)%20using%20width%3D1280%20and%20height%3D720%2C%20the%20pictures%20are%20represented%20correctly%20as%20expected.%3C%2FP%3E%3CP%3EI%20would%20like%20to%20have%20a%20confirmation%20that%20this%20is%20the%20normal%20behavior%20or%20not%20(because%20to%20be%20honest%20I%20expect%20to%20get%20the%20example%20already%20working%20correctly%20in%20horizontal%20way%2C%20so%20my%20doubt%20is%20that%20I'm%20making%20something%20wrong%20on%20another%20setting%20of%20GUI%20Guider%20or%20in%20a%20HW%20setting%20of%20the%20evaluation%20board).%3C%2FP%3E%3CP%3EThnak%20you%20and%20kind%20regards%2C%3C%2FP%3E%3CP%3EFrancesco%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GUI%20Guider%20examples%20Horizontal%20vs%20Vertical%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you.%20To%20be%20honest%20it%20seems%20to%20be%20that%20also%20in%20GUI%20Guider%201.10.0%20there%20isn't%20a%20horizontal%20option%20720x1280.%20Anyway%20it's%20not%20a%20problem.%20Thanks%20for%20confirmation%20that%20I'm%20doing%20the%20correct%20thing.%3C%2FP%3E%3CP%3EKind%20regards%2C%3C%2FP%3E%3CP%3EFrancesco%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GUI%20Guider%20examples%20Horizontal%20vs%20Vertical%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255225%22%20target%3D%22_blank%22%3E%40SolitoFrancesco%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EYes%2C%20this%20would%20be%20the%20method%20to%20use%20on%20versions%20of%20GUI%20Guider%20that%20don't%20have%20the%20option%20of%201280x720%20natively.%3C%2FP%3E%0A%3CP%3EThat%20said%2C%20I%20would%20like%20to%20add%20a%20recommendation%20to%20make%20sure%20you%20are%20using%20the%20latest%20version%20of%20GUI%20Guider%20(v1.10.0).%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E
