Freemaster connection failed
1,468 次查看
VARSHA_PRIYADARSINI
When I try to link freeMASTER to bind the variables, i get an error called "Failed to link FreeMASTER, please check IP and port!
In link config:
Address: localhost
Port: 41000
Can someone explain why this is happening and how to link freeMASTER in gui guider
1,453 次查看
LiubinGong
Hello @VARSHA_PRIYADARSINI
    Thanks for your feedback,  First you need to open the FreeMaster IDE, then link the server in GUI Guider. If you have opened multiple Freemaster instances, select the corresponding port number. Please find more information from FreeMASTER debug steps.  Hope this helps.
Best Regards
Liubin
