Can you remove the warning prompt for Play Button?
bosnian_beast
Warning
Auto generated code will be rewritten, do you want to continue?
Do not ask again
Can you remove this prompt, or at least make some config file where I can disable it?
Sometimes I am reopening GUI Guider multiple times because of changes in .guiguider file (git checkout, reset or similar) and every time I have to go through this pop up. For me it is really unnecessary and obsolete.
Hello @bosnian_beast
Thanks for your sharing, I know your meaning now, I will report it to development team, thanks.
Alice
How about check "Do not ask again" ?
Alice
bosnian_beast
I'm sorry, I wasn't clear enough. The "Do not ask again" is valid only while the GUI Guider is open. Every time you close it, this button gets reset. You can see why this is a problem if I have to close-and-open GG multiple times.
Alice
