there has no FreeMaster plug-in module
Tony_0726
I installed freemaster version 3.2.7, and tried many methods, but there's nothing under the plug-in module。I'm in a hurry. This is a necessary tool for my work. Can someone help me? Thank you very much.
1.install FreeMASTER "as administrator" or run the "c:\NXP\FreeMASTER 3.2\FreeMASTER\register.bat----no effect!!!PixPin_2026-07-20_20-46-19.png
MichalH
NXP Apps Support
NXP Apps Support
as far as I know, the latest Windows update does not change the way the COM+ and ActiveX objects work. This shall not be related. The issue you are facing is strange indeed.
Let's pick up one plug-in (CAN communication) and see its registration details.
Run the "command prompt" as administrator again, then cd to "c:\NXP\FreeMASTER 3.2\FreeMASTER" and use the regsvr32 command without the /s (silent) option:
regsvr32 plugins/can/focpgi.dll
The confirmation shall appear:
Then in the same Command Prompt console, start the Registry Editor by command:
regedit
It will take some time (can be few minutes) then the editor will appear. Navigate to
Computer\HKEY_CLASSES_ROOT\WOW6432Node\CLSID\{C10A92C3-7D47-4FDC-94B6-64B8E5C85E01}
This entry represents the FreeMASTER-over-CAN plugin (focpgi.dll). It shall be present in the registry.
You can check the InprocServer32 entry points to the correct focpgi.dll file.
The "Implemented Categories" ID is the one FreeMASTER uses to locate all plug ins using Windows COM Category API. Just to be sure the plug-in category exist, please check the Computer\HKEY_CLASSES_ROOT\Component Categories\{48A185C0-FFDB-11D3-80E3-00C04F176153} key in the Registry editor, you shall see the "MCB Communication Plugins" text value:
Another experiment would be to remove the /s switch from register.bat script and run it. You shall see a registration confirmation box for each DLL.
Please share the respective screenshots or errors. Thank you for your cooperation.
Michal
Tony_0726
Hello, I've tested again. Currently, that module is still not available. I've removed all the lines containing "/s" in the register.bat file. Are there any other solutions available now?1.png2.png3.png4.png5.png
MichalH
NXP Apps Support
NXP Apps Support
to summarize - all plugin registrations finish successfully, but the plugin list in FreeMASTER Options dialog is still empty.
Is there any chance you could test on a different computer?
Also, there are two other utilities which access the plugin list. Please try to run the Remote Server tool ("c:\NXP\FreeMASTER 3.2\FreeMASTER\mcbsvr.exe"). Then press the "Add" button and see if the plug-in list will also be empty:
A similar can be tried in "Named Connection" manager (c:\NXP\FreeMASTER 3.2\FreeMASTER\pgimgr.exe", then press the "New" button:
Let me know if any of the two tools would display the plugin list not empty.
Thank you,
Michal
Tony_0726
I've tried, but it still doesn't work. I have a lot of data on my computer and I don't want to reinstall the system. This is really troublesome.I was functioning normally before, but one day it suddenly stopped being able to connect.1.png2.png
MichalH
NXP Apps Support
NXP Apps Support
I have prepared a small test utility which shall help us detect what is wrong on your machine. Please see "plugin_test.exe" attached below.
Run it on cmd Command Prompt console (no need to run as administrator).
Usage: plugin_test <test#> [ProgID|CLSID]
test# 0 - create and release the component
test# 1 - create and call Configure()
test# 2 - enumerate all registered McbCommPlugin components
(ProgID|CLSID argument is optional for test 2)
The test of selected plugin instantiation could pass. Try this:
plugin_test.exe 0 MCBPGI.TCPSERIAL.1
Component : MCBPGI.TCPSERIAL.1
CLSID : {ED244618-9103-41BE-B382-E92036BD04FC}
Test : 0
[test 0] CoCreateInstance ...
[test 0] OK - component created successfully.
[test 0] Releasing ...
[test 0] Released.
Result: PASS
The tool can even try to display the plugin configuration dialog:
plugin_test.exe 1 MCBPGI.TCPSERIAL.1
And it shall appear:
Finally, the test 2 does plug-in enumeration similarly to FreeMASTER. It will most likely fail at your side:
plugin_test.exe 2
Test : 2
[test 2] Creating StdComponentCategoriesMgr ...
[test 2] OK - ICatInformation obtained.
[test 2] Enumerating McbCommPlugin classes:
[1] {1BB3C904-F1F4-4652-92EE-368716FE1D10} (BDMPGI.DAPCOM.1)
[2] {2080BBA8-0641-4306-A956-6BEBB7C75249} (JTAGPGI.CCSCOM.1)
[3] {225E034C-1AA6-4EC5-9A6C-A9FA9E890373} (BDMPGI.HCSCOM.1)
[4] {30AB7AA1-493A-4DD7-9509-C9C91EFFF0FD} (BDMPGI.PDBDMCOM.1)
[5] {5A129680-897E-4014-916D-9B1FE13DE156} (BDMPGI.EONCECOM.1)
[6] {6D13CD9D-9F2D-4066-B655-45B54CA7494B} (MCBPGI.NETCOM.1)
[7] {7AC03FB7-4792-4F26-8152-92E466276068} (DEMOPGI.DummyCom.1)
[8] {80F17965-EDBD-41F1-9182-3C44E04E5794} (BDMPGI.ISYSCOM.1)
[9] {8C575DB3-9769-4B66-AB60-C83CEA683E01} (BDMPGI.JLINKCOM.1)
[10] {C10A92C3-7D47-4FDC-94B6-64B8E5C85E01} (FOCPGI.FocCom.1)
[11] {C10A92C4-7D47-4FDC-94B6-64B8E5C85E01} (FOLPGI.FolCom.1)
[12] {ED244616-9103-41BE-B382-E92036BD04FC} (MCBPGI.STDCOM.1)
[13] {ED244617-9103-41BE-B382-E92036BD04FC} (MCBPGI.HTTPCOM.1)
[14] {ED244618-9103-41BE-B382-E92036BD04FC} (MCBPGI.TCPSERIAL.1)
[test 2] Total: 14 plug-in(s) found.
Result: PASS
Thank you for your cooperation,
Michal
Tony_0726
MichalH
NXP Apps Support
NXP Apps Support
Thanks for making the experiment.
Did any dialog appear in the "test 1" started like this:
Also, can you please run the test 2 in a command prompt which was started "As administrator" ?
plugin_test.exe 2
Thank you,
Michal
Tony_0726
1. The plugin_test.exe 1 MCBPGI.TCPSERIAL.1 has a dialog box.
2. The plugin_test.exe 2 has been run with administrator privileges.1.png2.png
MichalH
NXP Apps Support
NXP Apps Support
Hello thanks for keeping trying.
Let me summarize the facts - translated a bit to Windows programming API as used in FreeMASTER:
  • The API EnumClassesOfCategories() returns empty list even if components are registered properly with all registry entries and even if executed with administrator rights.
  • The EnumClassesOfCategories() return S_OK but the Next() called on the returned iterator does not enumerate anything.
  • Both the component DLLs and the app which enumerates them are compiled as 32bit code.
  • This issue is only observed on a single computer, many other computers work fine.
  • The CoCreateInstance on the target CLSID work well even on this problematic computer.
I have to admit I do not know what could be the reason. Some internet sources recommend to try un-registering and then registering the Windows component manager. So please try this in cmd under administrator and then restart the system:
regsvr32 /u comcat.dll
regsvr32 comcat.dll
regsvr32 /u c:\Windows\SysWOW64\comcat.dll
regsvr32 c:\Windows\SysWOW64\comcat.dll
You should get a confirmation box for each command.
If this does not help, I will continue investigation.
Michal
Tony_0726
Thank you very much for your assistance during this period, but it didn't work this time either.
Tony_0726
If someone can help me solve this problem, I will treat him to coffee.
MichalH
NXP Apps Support
NXP Apps Support
both the installer and the register.bat use the "regsvr32.exe" system utility, which shall be installed by default in any Windows operating system.
First, make sure the regsvr32 utility exists on your system. Just press Win+R and Run the command "regsvr32".
You should see the a help box like this one:
If this utility does not work, your computer might have a system restriction applied by your administrator. You will need to get it fixed.
If the regsvr32 works normally, let's see what errors the register.bat prints:
  1. Open the start menu.
  2. Locate the "Command Prompt" application
  3. Right-click and select "Run as administrator" (see picture below)
  4. In the console, type cd "c:\NXP\FreeMASTER 3.2\FreeMASTER"
  5. Run register.bat
  6. You should see no errors (like in the picture at the end).
  7. If no errors, the plug-ins shall appear in FreeMASTER. If there are any errors, please share it here.
Michal
Tony_0726
I have tried installing your method, but the module still hasn't appeared.
Is this related to my Windows system being updated to the latest version?ScreenShot_2026-07-21_095319_274.pngPixPin_2026-07-21_10-13-18.png
%3CLINGO-SUB%20id%3D%22lingo-sub-2396796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ethere%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CBR%20%2F%3EI%20installed%20freemaster%20version%203.2.7%2C%20and%20tried%20many%20methods%2C%20but%20there's%20nothing%20under%20the%20plug-in%20module%E3%80%82I'm%20in%20a%20hurry.%20This%20is%20a%20necessary%20tool%20for%20my%20work.%20Can%20someone%20help%20me%3F%20Thank%20you%20very%20much.%3C%2FP%3E%3CP%3E1.i%3CSPAN%3Enstall%20FreeMASTER%20%22as%20administrator%22%20or%20run%20the%26nbsp%3B%22c%3A%5CNXP%5CFreeMASTER%203.2%5CFreeMASTER%5Cregister.bat----no%20effect%EF%BC%81%EF%BC%81%EF%BC%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392663i47CA1166972FB79C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22PixPin_2026-07-20_20-46-19.png%22%20alt%3D%22PixPin_2026-07-20_20-46-19.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E2.%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20style%3D%22width%3A%20706px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392661i3EEBE5FA386DEDC6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22PixPin_2026-07-20_20-36-29.png%22%20alt%3D%22PixPin_2026-07-20_20-36-29.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392662i507B4915B7B4066D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22PixPin_2026-07-20_20-40-48.png%22%20alt%3D%22PixPin_2026-07-20_20-40-48.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2397041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397041%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3Eas%20far%20as%20I%20know%2C%20the%20latest%20Windows%20update%20does%20not%20change%20the%20way%20the%20COM%2B%20and%20ActiveX%20objects%20work.%20This%20shall%20not%20be%20related.%20The%20issue%20you%20are%20facing%20is%20strange%20indeed.%26nbsp%3B%3C%2FP%3E%0A%3CP%3ELet's%20pick%20up%20one%20plug-in%20(CAN%20communication)%20and%20see%20its%20registration%20details.%3C%2FP%3E%0A%3CP%3ERun%20the%20%22command%20prompt%22%20%3CSTRONG%3Eas%20administrator%3C%2FSTRONG%3E%26nbsp%3Bagain%2C%20then%20%3CSTRONG%3Ecd%3C%2FSTRONG%3E%20to%26nbsp%3B%22c%3A%5CNXP%5CFreeMASTER%203.2%5CFreeMASTER%22%20and%20use%20the%20regsvr32%20command%20without%20the%20%2Fs%20(silent)%20option%3A%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3Eregsvr32%20plugins%2Fcan%2Ffocpgi.dll%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EThe%20confirmation%20shall%20appear%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_1-1784615468404.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784615468404.png%22%20style%3D%22width%3A%20371px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784615468404.png%22%20style%3D%22width%3A%20371px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784615468404.png%22%20style%3D%22width%3A%20371px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784615468404.png%22%20style%3D%22width%3A%20371px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784615468404.png%22%20style%3D%22width%3A%20371px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784615468404.png%22%20style%3D%22width%3A%20371px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784615468404.png%22%20style%3D%22width%3A%20371px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784615468404.png%22%20style%3D%22width%3A%20371px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784615468404.png%22%20style%3D%22width%3A%20371px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784615468404.png%22%20style%3D%22width%3A%20371px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392729iA877A700F46C7E69%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MichalH_1-1784615468404.png%22%20alt%3D%22MichalH_1-1784615468404.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThen%20in%20the%20same%20Command%20Prompt%20console%2C%20start%20the%20Registry%20Editor%20by%20command%3A%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3Eregedit%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EIt%20will%20take%20some%20time%20(can%20be%20few%20minutes)%20then%20the%20editor%20will%20appear.%20Navigate%20to%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EComputer%5CHKEY_CLASSES_ROOT%5CWOW6432Node%5CCLSID%5C%7BC10A92C3-7D47-4FDC-94B6-64B8E5C85E01%7D%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EThis%20entry%20represents%20the%20FreeMASTER-over-CAN%20plugin%20(focpgi.dll).%20It%20shall%20be%20present%20in%20the%20registry.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_0-1784615359152.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784615359152.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784615359152.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784615359152.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784615359152.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784615359152.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784615359152.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784615359152.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784615359152.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784615359152.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784615359152.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392728i00CE105BC6C87066%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MichalH_0-1784615359152.png%22%20alt%3D%22MichalH_0-1784615359152.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EYou%20can%20check%20the%20InprocServer32%20entry%20points%20to%20the%20correct%20focpgi.dll%20file.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_2-1784615691533.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784615691533.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784615691533.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784615691533.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784615691533.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784615691533.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784615691533.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784615691533.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784615691533.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784615691533.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784615691533.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392730i60C7F8E52AA87456%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MichalH_2-1784615691533.png%22%20alt%3D%22MichalH_2-1784615691533.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThe%20%22Implemented%20Categories%22%20ID%20is%20the%20one%20FreeMASTER%20uses%20to%20locate%20all%20plug%20ins%20using%20Windows%20%3CA%20href%3D%22https%3A%2F%2Flearn.microsoft.com%2Fen-us%2Fwindows%2Fwin32%2Fapi%2Fcomcat%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ECOM%20Category%20API%3C%2FA%3E.%20Just%20to%20be%20sure%20the%20plug-in%20category%20exist%2C%20please%20check%20the%26nbsp%3B%3CSTRONG%3EComputer%5CHKEY_CLASSES_ROOT%5CComponent%20Categories%5C%7B48A185C0-FFDB-11D3-80E3-00C04F176153%7D%3C%2FSTRONG%3E%20key%20in%20the%20Registry%20editor%2C%20you%20shall%20see%20the%20%22MCB%20Communication%20Plugins%22%20text%20value%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_3-1784615997310.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784615997310.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784615997310.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784615997310.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784615997310.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784615997310.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784615997310.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784615997310.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784615997310.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784615997310.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784615997310.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392731i6BBE18035BF703F2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MichalH_3-1784615997310.png%22%20alt%3D%22MichalH_3-1784615997310.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EAnother%20experiment%20would%20be%20to%20remove%20the%20%2Fs%20switch%20from%20register.bat%20script%20and%20run%20it.%20You%20shall%20see%20a%20registration%20confirmation%20box%20for%20each%20DLL.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20share%20the%20respective%20screenshots%20or%20errors.%20Thank%20you%20for%20your%20cooperation.%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3EMichal%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396977%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIf%20someone%20can%20help%20me%20solve%20this%20problem%2C%20I%20will%20treat%20him%20to%20coffee.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396976%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20tried%20installing%20your%20method%2C%20but%20the%20module%20still%20hasn't%20appeared.%3C%2FP%3E%3CP%3EIs%20this%20related%20to%20my%20Windows%20system%20being%20updated%20to%20the%20latest%20version%3F%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392707i1F74C75F9731AEF0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22ScreenShot_2026-07-21_095319_274.png%22%20alt%3D%22ScreenShot_2026-07-21_095319_274.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392708iCFAA4B4E7B8DDC63%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22PixPin_2026-07-21_10-13-18.png%22%20alt%3D%22PixPin_2026-07-21_10-13-18.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3Eboth%20the%20installer%20and%20the%20register.bat%20use%20the%20%22%3CSTRONG%3Eregsvr32.exe%3C%2FSTRONG%3E%22%20system%20utility%2C%20which%20shall%20be%20installed%20by%20default%20in%20any%20Windows%20operating%20system.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EFirst%2C%20make%20sure%20the%20regsvr32%20utility%20exists%20on%20your%20system.%20Just%20press%20Win%2BR%20and%20Run%20the%20command%20%22regsvr32%22.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_3-1784558060323.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784558060323.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784558060323.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784558060323.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784558060323.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784558060323.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784558060323.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784558060323.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784558060323.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784558060323.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_3-1784558060323.png%22%20style%3D%22width%3A%20399px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392677i4B77D51C8105C6B4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MichalH_3-1784558060323.png%22%20alt%3D%22MichalH_3-1784558060323.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EYou%20should%20see%20the%20a%20help%20box%20like%20this%20one%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_0-1784557473602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784557473602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784557473602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784557473602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784557473602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784557473602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784557473602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784557473602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784557473602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784557473602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784557473602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392674i5F5FB23F94CFF78A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MichalH_0-1784557473602.png%22%20alt%3D%22MichalH_0-1784557473602.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIf%20this%20utility%20does%20not%20work%2C%20your%20computer%20might%20have%20a%20system%20restriction%20applied%20by%20your%20administrator.%20You%20will%20need%20to%20get%20it%20fixed.%3C%2FP%3E%0A%3CP%3EIf%20the%20regsvr32%20works%20normally%2C%20let's%20see%20what%20errors%20the%20register.bat%20prints%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3EOpen%20the%20start%20menu.%3C%2FLI%3E%0A%3CLI%3ELocate%20the%20%22Command%20Prompt%22%20application%3C%2FLI%3E%0A%3CLI%3ERight-click%20and%20select%20%22Run%20as%20administrator%22%20(see%20picture%20below)%3C%2FLI%3E%0A%3CLI%3EIn%20the%20console%2C%20type%26nbsp%3B%3CSTRONG%3Ecd%20%22c%3A%5CNXP%5CFreeMASTER%203.2%5CFreeMASTER%22%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3ERun%26nbsp%3B%3CSTRONG%3Eregister.bat%3C%2FSTRONG%3E%3C%2FLI%3E%0A%3CLI%3EYou%20should%20see%20no%20errors%20(like%20in%20the%20picture%20at%20the%20end).%3C%2FLI%3E%0A%3CLI%3EIf%20no%20errors%2C%20the%20plug-ins%20shall%20appear%20in%20FreeMASTER.%20If%20there%20are%20any%20errors%2C%20please%20share%20it%20here.%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_1-1784557809666.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784557809666.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784557809666.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784557809666.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784557809666.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784557809666.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784557809666.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784557809666.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784557809666.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784557809666.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784557809666.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392675i8ED3A5D03CCD22B8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MichalH_1-1784557809666.png%22%20alt%3D%22MichalH_1-1784557809666.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_2-1784557992554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784557992554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784557992554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784557992554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784557992554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784557992554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784557992554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784557992554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784557992554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784557992554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_2-1784557992554.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392676iFE0F0F13A4161EBB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MichalH_2-1784557992554.png%22%20alt%3D%22MichalH_2-1784557992554.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3EMichal%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2397464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I've%20tested%20again.%20Currently%2C%20that%20module%20is%20still%20not%20available.%20I've%20removed%20all%20the%20lines%20containing%20%22%2Fs%22%20in%20the%20register.bat%20file.%20Are%20there%20any%20other%20solutions%20available%20now%3F%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392833iF018CD2D1546A2D7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392834i48132C2A658327BF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392835iCBA382D84F19D05F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223.png%22%20alt%3D%223.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%224.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392836iBB6E454BE766D0DA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%224.png%22%20alt%3D%224.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392837i6BB69EC085016A47%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%225.png%22%20alt%3D%225.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2397566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397566%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3Eto%20summarize%20-%20all%20plugin%20registrations%20finish%20successfully%2C%20but%20the%20plugin%20list%20in%20FreeMASTER%20Options%20dialog%20is%20still%20empty.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIs%20there%20any%20chance%20you%20could%20test%20on%20a%20different%20computer%3F%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAlso%2C%20there%20are%20two%20other%20utilities%20which%20access%20the%20plugin%20list.%20Please%20try%20to%20run%20the%20Remote%20Server%20tool%20(%22c%3A%5CNXP%5CFreeMASTER%203.2%5CFreeMASTER%5Cmcbsvr.exe%22).%26nbsp%3BThen%20press%20the%20%22Add%22%20button%20and%20see%20if%20the%20plug-in%20list%20will%20also%20be%20empty%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_0-1784702997668.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784702997668.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784702997668.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784702997668.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784702997668.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784702997668.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784702997668.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784702997668.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784702997668.png%22%20style%3D%22width%3A%20745px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392867i94EBA827E199DCFD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MichalH_0-1784702997668.png%22%20alt%3D%22MichalH_0-1784702997668.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EA%20similar%20can%20be%20tried%20in%20%22Named%20Connection%22%20manager%20(c%3A%5CNXP%5CFreeMASTER%203.2%5CFreeMASTER%5Cpgimgr.exe%22%2C%20then%20press%20the%20%22New%22%20button%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_1-1784703133393.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784703133393.png%22%20style%3D%22width%3A%20557px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784703133393.png%22%20style%3D%22width%3A%20557px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784703133393.png%22%20style%3D%22width%3A%20557px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784703133393.png%22%20style%3D%22width%3A%20557px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784703133393.png%22%20style%3D%22width%3A%20557px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784703133393.png%22%20style%3D%22width%3A%20557px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784703133393.png%22%20style%3D%22width%3A%20557px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_1-1784703133393.png%22%20style%3D%22width%3A%20557px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392869i6A24FBF1DB2CFDD8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MichalH_1-1784703133393.png%22%20alt%3D%22MichalH_1-1784703133393.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ELet%20me%20know%20if%20any%20of%20the%20two%20tools%20would%20display%20the%20plugin%20list%20not%20empty.%3C%2FP%3E%0A%3CP%3EThank%20you%2C%3CBR%20%2F%3EMichal%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2397956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397956%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20tried%2C%20but%20it%20still%20doesn't%20work.%20I%20have%20a%20lot%20of%20data%20on%20my%20computer%20and%20I%20don't%20want%20to%20reinstall%20the%20system.%20This%20is%20really%20troublesome.I%20was%20functioning%20normally%20before%2C%20but%20one%20day%20it%20suddenly%20stopped%20being%20able%20to%20connect.%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20545px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392968iE0FD6955B88D99BF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20695px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20695px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20695px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20695px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20695px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20695px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20695px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20695px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392969i654DE6DDCD52015B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2398100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20have%20prepared%20a%20small%20test%20utility%20which%20shall%20help%20us%20detect%20what%20is%20wrong%20on%20your%20machine.%20Please%20see%20%22plugin_test.exe%22%20attached%20below.%26nbsp%3B%3C%2FP%3E%0A%3CP%3ERun%20it%20on%20cmd%20Command%20Prompt%20console%20(no%20need%20to%20run%20as%20administrator).%3C%2FP%3E%0A%3CPRE%3EUsage%3A%20plugin_test%20%3CTEST%3E%20%5BProgID%7CCLSID%5D%3CBR%20%2F%3E%3CBR%20%2F%3Etest%23%200%20-%20create%20and%20release%20the%20component%3CBR%20%2F%3Etest%23%201%20-%20create%20and%20call%20Configure()%3CBR%20%2F%3Etest%23%202%20-%20enumerate%20all%20registered%20McbCommPlugin%20components%3CBR%20%2F%3E(ProgID%7CCLSID%20argument%20is%20optional%20for%20test%202)%3C%2FTEST%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThe%20test%20of%20selected%20plugin%20instantiation%20could%20pass.%20Try%20this%3A%3C%2FP%3E%0A%3CPRE%3E%3CSTRONG%3Eplugin_test.exe%200%20MCBPGI.TCPSERIAL.1%3C%2FSTRONG%3E%3CBR%20%2F%3EComponent%20%3A%20MCBPGI.TCPSERIAL.1%3CBR%20%2F%3ECLSID%20%3A%20%7BED244618-9103-41BE-B382-E92036BD04FC%7D%3CBR%20%2F%3ETest%20%3A%200%3CBR%20%2F%3E%3CBR%20%2F%3E%5Btest%200%5D%20CoCreateInstance%20...%3CBR%20%2F%3E%5Btest%200%5D%20OK%20-%20component%20created%20successfully.%3CBR%20%2F%3E%5Btest%200%5D%20Releasing%20...%3CBR%20%2F%3E%5Btest%200%5D%20Released.%3CBR%20%2F%3E%3CBR%20%2F%3EResult%3A%20PASS%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThe%20tool%20can%20even%20try%20to%20display%20the%20plugin%20configuration%20dialog%3A%3C%2FP%3E%0A%3CPRE%3E%3CSTRONG%3Eplugin_test.exe%201%20MCBPGI.TCPSERIAL.1%3C%2FSTRONG%3E%3C%2FPRE%3E%0A%3CP%3E%3CSTRONG%3EAnd%20it%20shall%20appear%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_0-1784793243679.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784793243679.png%22%20style%3D%22width%3A%20358px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784793243679.png%22%20style%3D%22width%3A%20358px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784793243679.png%22%20style%3D%22width%3A%20358px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784793243679.png%22%20style%3D%22width%3A%20358px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784793243679.png%22%20style%3D%22width%3A%20358px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1784793243679.png%22%20style%3D%22width%3A%20358px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393028i9594003960DC4427%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22MichalH_0-1784793243679.png%22%20alt%3D%22MichalH_0-1784793243679.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EFinally%2C%20the%20test%202%20does%20plug-in%20enumeration%20similarly%20to%20FreeMASTER.%20It%20will%20most%20likely%20fail%20at%20your%20side%3A%3C%2FP%3E%0A%3CPRE%3E%3CSTRONG%3Eplugin_test.exe%202%3C%2FSTRONG%3E%3CBR%20%2F%3ETest%20%3A%202%3CBR%20%2F%3E%3CBR%20%2F%3E%5Btest%202%5D%20Creating%20StdComponentCategoriesMgr%20...%3CBR%20%2F%3E%5Btest%202%5D%20OK%20-%20ICatInformation%20obtained.%3CBR%20%2F%3E%5Btest%202%5D%20Enumerating%20McbCommPlugin%20classes%3A%3CBR%20%2F%3E%5B1%5D%20%7B1BB3C904-F1F4-4652-92EE-368716FE1D10%7D%20(BDMPGI.DAPCOM.1)%3CBR%20%2F%3E%5B2%5D%20%7B2080BBA8-0641-4306-A956-6BEBB7C75249%7D%20(JTAGPGI.CCSCOM.1)%3CBR%20%2F%3E%5B3%5D%20%7B225E034C-1AA6-4EC5-9A6C-A9FA9E890373%7D%20(BDMPGI.HCSCOM.1)%3CBR%20%2F%3E%5B4%5D%20%7B30AB7AA1-493A-4DD7-9509-C9C91EFFF0FD%7D%20(BDMPGI.PDBDMCOM.1)%3CBR%20%2F%3E%5B5%5D%20%7B5A129680-897E-4014-916D-9B1FE13DE156%7D%20(BDMPGI.EONCECOM.1)%3CBR%20%2F%3E%5B6%5D%20%7B6D13CD9D-9F2D-4066-B655-45B54CA7494B%7D%20(MCBPGI.NETCOM.1)%3CBR%20%2F%3E%5B7%5D%20%7B7AC03FB7-4792-4F26-8152-92E466276068%7D%20(DEMOPGI.DummyCom.1)%3CBR%20%2F%3E%5B8%5D%20%7B80F17965-EDBD-41F1-9182-3C44E04E5794%7D%20(BDMPGI.ISYSCOM.1)%3CBR%20%2F%3E%5B9%5D%20%7B8C575DB3-9769-4B66-AB60-C83CEA683E01%7D%20(BDMPGI.JLINKCOM.1)%3CBR%20%2F%3E%5B10%5D%20%7BC10A92C3-7D47-4FDC-94B6-64B8E5C85E01%7D%20(FOCPGI.FocCom.1)%3CBR%20%2F%3E%5B11%5D%20%7BC10A92C4-7D47-4FDC-94B6-64B8E5C85E01%7D%20(FOLPGI.FolCom.1)%3CBR%20%2F%3E%5B12%5D%20%7BED244616-9103-41BE-B382-E92036BD04FC%7D%20(MCBPGI.STDCOM.1)%3CBR%20%2F%3E%5B13%5D%20%7BED244617-9103-41BE-B382-E92036BD04FC%7D%20(MCBPGI.HTTPCOM.1)%3CBR%20%2F%3E%5B14%5D%20%7BED244618-9103-41BE-B382-E92036BD04FC%7D%20(MCBPGI.TCPSERIAL.1)%3CBR%20%2F%3E%5Btest%202%5D%20Total%3A%2014%20plug-in(s)%20found.%3CBR%20%2F%3E%3CBR%20%2F%3EResult%3A%20PASS%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThank%20you%20for%20your%20cooperation%2C%3C%2FP%3E%0A%3CP%3EMichal%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20thanks%20for%20keeping%20trying.%3C%2FP%3E%0A%3CP%3ELet%20me%20summarize%20the%20facts%20-%20translated%20a%20bit%20to%20Windows%20programming%20API%20as%20used%20in%20FreeMASTER%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EThe%20API%20EnumClassesOfCategories()%20returns%20empty%20list%20even%20if%20components%20are%20registered%20properly%20with%20all%20registry%20entries%20and%20even%20if%20executed%20with%20administrator%20rights.%3C%2FLI%3E%0A%3CLI%3EThe%20EnumClassesOfCategories()%20return%20S_OK%20but%20the%20Next()%20called%20on%20the%20returned%20iterator%20does%20not%20enumerate%20anything.%3C%2FLI%3E%0A%3CLI%3EBoth%20the%20component%20DLLs%20and%20the%20app%20which%20enumerates%20them%20are%20compiled%20as%2032bit%20code.%3C%2FLI%3E%0A%3CLI%3EThis%20issue%20is%20only%20observed%20on%20a%20single%20computer%2C%20many%20other%20computers%20work%20fine.%3C%2FLI%3E%0A%3CLI%3EThe%20CoCreateInstance%20on%20the%20target%20CLSID%20work%20well%20even%20on%20this%20problematic%20computer.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EI%20have%20to%20admit%20I%20do%20not%20know%20what%20could%20be%20the%20reason.%20Some%20internet%20sources%20recommend%20to%20try%20un-registering%20and%20then%20registering%20the%20Windows%20component%20manager.%20So%20please%20try%20this%20in%20%3CSTRONG%3Ecmd%20under%20administrator%20and%20then%20restart%20the%20system%3A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CPRE%3E%3CSTRONG%3Eregsvr32%20%2Fu%20comcat.dll%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Eregsvr32%20comcat.dll%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Eregsvr32%20%2Fu%20c%3A%5CWindows%5CSysWOW64%5Ccomcat.dll%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3Eregsvr32%20c%3A%5CWindows%5CSysWOW64%5Ccomcat.dll%3C%2FSTRONG%3E%3C%2FPRE%3E%0A%3CP%3EYou%20should%20get%20a%20confirmation%20box%20for%20each%20command.%3C%2FP%3E%0A%3CP%3EIf%20this%20does%20not%20help%2C%20I%20will%20continue%20investigation.%3C%2FP%3E%0A%3CP%3EThanks%2C%3CBR%20%2F%3EMichal%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20making%20the%20experiment.%3C%2FP%3E%0A%3CP%3EDid%20any%20dialog%20appear%20in%20the%20%22test%201%22%20started%20like%20this%3A%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CSTRONG%3Eplugin_test.exe%201%20MCBPGI.TCPSERIAL.1%3C%2FSTRONG%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3EAlso%2C%20can%20you%20please%20run%20the%20%3CSTRONG%3Etest%202%3C%2FSTRONG%3E%20in%20a%20command%20prompt%20which%20was%20started%20%3CSTRONG%3E%22As%20administrator%22%3C%2FSTRONG%3E%20%3F%3C%2FP%3E%0A%3CPRE%3E%3CSTRONG%3Eplugin_test.exe%202%3C%2FSTRONG%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThank%20you%2C%3CBR%20%2F%3EMichal%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399047%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20tested%20it%2C%20but%20it%20didn't%20work.%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393203i53FABF7932C5D68C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393204iD2714D7E78DA99DD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393202i4A4186B01B887FD4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223.png%22%20alt%3D%223.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399131%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399131%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E1.%20The%20plugin_test.exe%201%20MCBPGI.TCPSERIAL.1%20has%20a%20dialog%20box.%3C%2FP%3E%3CP%3E2.%20The%20plugin_test.exe%202%20has%20been%20run%20with%20administrator%20privileges.%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393230iC896F08A4C546E68%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393229iDEDD326222322F99%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20there%20has%20no%20FreeMaster%20plug-in%20module%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20very%20much%20for%20your%20assistance%20during%20this%20period%2C%20but%20it%20didn't%20work%20this%20time%20either.%3C%2FP%3E%3C%2FLINGO-BODY%3E
