View array/structures By FreeMaster?
3,424 次查看
Vergil
Dear ALL:
I can not view ariables of Array or variables of Structure when I use it on DSP.
Did I forget to add something or I use it in a wrong way? And it can not generate Array or Structure in the file .map.
Could you help me with this problem?
Vergil
3,389 次查看
MichalH
NXP Apps Support
NXP Apps Support
Please note that use of FreeMASTER with MCUs other than from NXP is prohibited by license terms. You have agreed to the terms when downloading and installing FreeMASTER.
FreeMASTER can only be used with systems based on NXP processing units. Others are not supported.
7 回复数
3,399 次查看
MichalH
NXP Apps Support
NXP Apps Support
please describe what MCU and what C compiler are you using.
Thank you,
Michal
3,394 次查看
Vergil
HELLO
FreeMaster is uesed on DSP320F28377D and I am using the CCS to complier.
One of SCI is used to connect PC and MCU by Free Master.
Thank you,
Vergil
3,390 次查看
MichalH
NXP Apps Support
NXP Apps Support
3,384 次查看
Vergil
Well, I'm so sorry. In this case, in order to avoid the terms, I had to re-purchase NXP chips to learn how to use the MCU. In addition, can you tell me whether using NXP processing unit can avoid such problems?
2,896 次查看
_S_M_B_
Hello, dear developer. Did you successfully used the FreeMaster on the C28x? I need some help because I can not use the correct map file.
2,888 次查看
MichalH
NXP Apps Support
NXP Apps Support
Please read the solution post of this thread.
Stop using FreeMASTER with other than NXP microcontrollers.
3,374 次查看
MichalH
NXP Apps Support
NXP Apps Support
Yes, by using systems based on NXP microcontroller devices, you will be able to use FreeMASTER without any licensing issues. Also the problem with arrays, structure members and other data type information retrieval is not affecting the NXP platforms.
Michal
