The plugin configuration dialog failed
Lucas593
The prompt appears after I finish configuring the CAN Communication: “The plugin configuration dialog failed. Try to specify the connect string manually.”
MichalH
NXP Apps Support
NXP Apps Support
Hello the version 3.2.7 has been released. This version fixes the CAN plug-in dependency issue discussed in this thread.
Michal
MichalH
NXP Apps Support
NXP Apps Support
until this issue is solved, please see a workaround discussed here.
Michal
MichalH
NXP Apps Support
NXP Apps Support
Michal
