The canfd configuration of freemaster
3,562 次查看
vcquwh
When configuring the can communication plugin, connection characters cannot be generated. Is there a new version of the can communication plugin for replacement?
15 回复数
3,537 次查看
MichalH
NXP Apps Support
NXP Apps Support
the error you show is a sign of wrong FreeMASTER installation. Please re-install the latest version (3.2.6) as administrator.  If you already have the latest version installed, you can fix the plug-in registration by running the "register.bat" as administrator. The register.bat is typically located in installation folder c:\NXP\FreeMASTER 3.2\FreeMASTER.
The version 3.2.6 brings updated CAN communication plug-in, which also supports CAN-FD mode for some host interfaces (IXXAT, Kvaser and ZLG).
Michal
3,527 次查看
vcquwh
When I downloaded the latest version (3.2.6), it showed that the installation was unsuccessful. However, when I installed the previous version again, the installation was successful。So I kept the new version of the plugin and put it in the old version, and the initial problem occurred
3,513 次查看
MichalH
NXP Apps Support
NXP Apps Support
let's try to solve the 3.2.6 installation issue. There are some typical issues when re-installing new versions described in this post.
Can you try to un-install the older version first, then clean/remove the C:\Program Files (x86)\Zero G Registry\.com.zerog.registry.xml file as discussed in that post?
After this, try to install 3.2.6 as administrator.
Michal
3,451 次查看
vcquwh
The installation log is displayed as follows
3,434 次查看
MichalH
NXP Apps Support
NXP Apps Support
The error=5 typically means "Access is denied" - for some reason your system does not allow plug-in registration. Do you run your installer "as administrator" ?
As a experiment, please start command line prompt "as administrator", then 'cd' to "c:\NXP\FreeMASTER 3.2\FreeMASTER" and run register.bat.
Send a screenshot of the console output.
Michal
3,428 次查看
vcquwh
But I can't open freemaster, even though I'm running it as an administrator
3,420 次查看
MichalH
NXP Apps Support
NXP Apps Support
Please try the experiment I suggested above:
Start "cmd" command line prompt "as administrator", then 'cd' to "c:\NXP\FreeMASTER 3.2\FreeMASTER" and run register.bat.
It should look similar to mine:
Michal
3,413 次查看
vcquwh
Yes, the same as yours
3,405 次查看
MichalH
NXP Apps Support
NXP Apps Support
It is not the same - notice the error messages in your output.
Please run this command in the same console:
       regsvr32 mcbobjps.dll
You shoud get a success message window. (but you will most likely get an error message):
Please share the output screenshot (You can use a pritnscreen key to get a screenshot to a clipboard and then Ctrl+V to message) .
Michal
3,240 次查看
vcquwh
What should I do next
3,186 次查看
MichalH
NXP Apps Support
NXP Apps Support
the error code 0x80070005 means Access Denied.  I suspect you have not used the "Run as administrator" when running the cmd.
Locate the register.bat file in Windows Explorer and run it "as administrator".
Michal
2,284 次查看
vcquwh
Is there any other reason? I had a problem during the installation. At that time, I didn't need to run this file yet
3,431 次查看
vcquwh
3,492 次查看
vcquwh
I tried again following your method, and the result was the same. In addition, the installation problem is the same when using a computer that has not installed this software before. Do you have any other solutions.  Besides, I want to know where I can see the installation logs. Thank you very much.
3,508 次查看
vcquwh
I have tried your method. If I don't delete that registration file, I won't be able to install it. Only after deleting it can I install it, but after installation, there will be a problem of unsuccessful installation. I'll try again after you say so. Thank you very much
%3CLINGO-SUB%20id%3D%22lingo-sub-2248923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Efreemaster%20%E7%9A%84%20canfd%20%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%85%8D%E7%BD%AE%20can%20%E9%80%9A%E4%BF%A1%E6%8F%92%E4%BB%B6%E6%97%B6%EF%BC%8C%E6%97%A0%E6%B3%95%E7%94%9F%E6%88%90%E8%BF%9E%E6%8E%A5%E5%AD%97%E7%AC%A6%E3%80%82%E6%98%AF%E5%90%A6%E6%9C%89%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20can%20communication%20%E6%8F%92%E4%BB%B6%E5%8F%AF%E4%BE%9B%E6%9B%BF%E6%8D%A2%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%204096px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764136326969.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367259i827CF1B24281C73E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%221764136326969.jpg%22%20alt%3D%221764136326969.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20canfd%20configuration%20of%20freemaster%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%BE%E7%A4%BA%E7%9A%84%E9%94%99%E8%AF%AF%E8%AF%B4%E6%98%8E%20FreeMASTER%20%E5%AE%89%E8%A3%85%E9%94%99%E8%AF%AF%E3%80%82%E8%AF%B7%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FFreeMASTER-Knowledge-Base%2FFreeMASTER-3-2-6-Update-Release-Announcement%2Fta-p%2F2199873%22%20target%3D%22_blank%22%3E%EF%BC%883.2.6%3C%2FA%3E%EF%BC%89%E3%80%82%20%E5%A6%82%E6%9E%9C%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E4%BA%86%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%EF%BC%8C%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E8%BF%90%E8%A1%8C%22register.bat%20%E6%9D%A5%E4%BF%AE%E5%A4%8D%E6%8F%92%E4%BB%B6%E6%B3%A8%E5%86%8C%E9%97%AE%E9%A2%98%E3%80%82%22%E4%BD%9C%E4%B8%BA%E7%AE%A1%E7%90%86%E5%91%98%E3%80%82register.bat%20%E9%80%9A%E5%B8%B8%E4%BD%8D%E4%BA%8E%E5%AE%89%E8%A3%85%E6%96%87%E4%BB%B6%E5%A4%B9%20c%3A%5CNXP%5CFreeMASTER%203.2%5CFreeMASTER%20%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CP%3E3.2.6%20%E7%89%88%E6%9B%B4%E6%96%B0%E4%BA%86%20CAN%20%E9%80%9A%E4%BF%A1%E6%8F%92%E4%BB%B6%EF%BC%8C%E6%9F%90%E4%BA%9B%E4%B8%BB%E6%9C%BA%E6%8E%A5%E5%8F%A3%EF%BC%88IXXAT%E3%80%81Kvaser%20%E5%92%8C%20ZLG%EF%BC%89%E8%BF%98%E6%94%AF%E6%8C%81%20CAN-FD%20%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EMichal%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20canfd%20configuration%20of%20freemaster%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E5%92%8C%E4%BD%A0%E7%9A%84%E4%B8%80%E6%A0%B7%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221764230596054.jpg%22%20style%3D%22width%3A%203072px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764230596054.jpg%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764230596054.jpg%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764230596054.jpg%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764230596054.jpg%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764230596054.jpg%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764230596054.jpg%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764230596054.jpg%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764230596054.jpg%22%20style%3D%22width%3A%20300px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764230596054.jpg%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764230596054.jpg%22%20style%3D%22width%3A%20300px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367557i751A45A0DF696D21%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%221764230596054.jpg%22%20alt%3D%221764230596054.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250234%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20canfd%20configuration%20of%20freemaster%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250234%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%8D%E4%B8%80%E6%A0%B7%E7%9A%84--%E6%B3%A8%E6%84%8F%E8%BE%93%E5%87%BA%E4%B8%AD%E7%9A%84%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%9C%A8%E5%90%8C%E4%B8%80%E6%8E%A7%E5%88%B6%E5%8F%B0%E8%BF%90%E8%A1%8C%E6%AD%A4%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%20%20%20%20%20%20%20regsvr32%20mcbobjps.dll%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%E4%B8%80%E4%B8%AA%E6%88%90%E5%8A%9F%E6%B6%88%E6%81%AF%E7%AA%97%E5%8F%A3%E3%80%82(%E4%BD%86%E4%BD%A0%E5%BE%88%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%94%B6%E5%88%B0%E4%B8%80%E6%9D%A1%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%EF%BC%89%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_0-1764232158985.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764232158985.png%22%20style%3D%22width%3A%20975px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764232158985.png%22%20style%3D%22width%3A%20975px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764232158985.png%22%20style%3D%22width%3A%20975px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764232158985.png%22%20style%3D%22width%3A%20975px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764232158985.png%22%20style%3D%22width%3A%20975px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764232158985.png%22%20style%3D%22width%3A%20975px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764232158985.png%22%20style%3D%22width%3A%20975px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764232158985.png%22%20style%3D%22width%3A%20975px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764232158985.png%22%20style%3D%22width%3A%20975px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367571i9CA3E4E182FB8EDB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MichalH_0-1764232158985.png%22%20alt%3D%22MichalH_0-1764232158985.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%88%86%E4%BA%AB%E8%BE%93%E5%87%BA%E6%88%AA%E5%9B%BE%EF%BC%88%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20pritnscreen%20%E9%94%AE%E5%B0%86%E6%88%AA%E5%9B%BE%E4%BF%9D%E5%AD%98%E5%88%B0%E5%89%AA%E8%B4%B4%E6%9D%BF%EF%BC%8C%E7%84%B6%E5%90%8E%E6%8C%89%20Ctrl%2BV%20%E5%8F%91%E9%80%81%E4%BF%A1%E6%81%AF%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EMichal%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20canfd%20configuration%20of%20freemaster%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E6%88%91%E4%B8%8A%E9%9D%A2%E5%BB%BA%E8%AE%AE%E7%9A%84%E5%AE%9E%E9%AA%8C%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E5%90%AF%E5%8A%A8%22cmd%22%20%E5%91%BD%E4%BB%A4%E8%A1%8C%E6%8F%90%E7%A4%BA%22%22%20%EF%BC%8C%E7%84%B6%E5%90%8E%20%22cd%20%22%E5%88%B0%22c%3A%5CNXP%5CFreeMASTER%203.2%5CFreeMASTER%22%20%E5%B9%B6%E8%BF%90%E8%A1%8C%20register.bat%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%91%E9%80%81%E6%8E%A7%E5%88%B6%E5%8F%B0%E8%BE%93%E5%87%BA%E7%9A%84%E6%88%AA%E5%9B%BE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%BA%94%E8%AF%A5%E5%92%8C%E6%88%91%E7%9A%84%E5%B7%AE%E4%B8%8D%E5%A4%9A%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_0-1764230285412.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764230285412.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764230285412.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764230285412.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764230285412.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764230285412.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764230285412.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764230285412.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764230285412.png%22%20style%3D%22width%3A%20858px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367549i06C976EAC1936000%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MichalH_0-1764230285412.png%22%20alt%3D%22MichalH_0-1764230285412.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3EMichal%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20canfd%20configuration%20of%20freemaster%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eerror%3D5%20%E9%80%9A%E5%B8%B8%E8%A1%A8%E7%A4%BA%22%E8%AE%BF%E9%97%AE%E8%A2%AB%E6%8B%92%E7%BB%9D%22%20-%20%E7%94%B1%E4%BA%8E%E6%9F%90%E4%BA%9B%E5%8E%9F%E5%9B%A0%EF%BC%8C%E6%82%A8%E7%9A%84%E7%B3%BB%E7%BB%9F%E4%B8%8D%E5%85%81%E8%AE%B8%E6%8F%92%E4%BB%B6%E6%B3%A8%E5%86%8C%E3%80%82%E6%82%A8%E6%98%AF%E5%90%A6%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%22%22%20%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%BD%9C%E4%B8%BA%E5%AE%9E%E9%AA%8C%EF%BC%8C%E8%AF%B7%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E5%90%AF%E5%8A%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%E6%8F%90%E7%A4%BA%22%22%20%EF%BC%8C%E7%84%B6%E5%90%8E%20%22cd%20%22%E5%88%B0%22c%3A%5CNXP%5CFreeMASTER%203.2%5CFreeMASTER%22%20%E5%B9%B6%E8%BF%90%E8%A1%8C%20register.bat%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%91%E9%80%81%E6%8E%A7%E5%88%B6%E5%8F%B0%E8%BE%93%E5%87%BA%E7%9A%84%E6%88%AA%E5%9B%BE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3EMichal%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20canfd%20configuration%20of%20freemaster%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%86%E6%88%91%E6%97%A0%E6%B3%95%E6%89%93%E5%BC%80%20freemaster%EF%BC%8C%E5%B0%BD%E7%AE%A1%E6%88%91%E6%98%AF%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%E7%9A%84%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20canfd%20configuration%20of%20freemaster%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249132%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E6%88%91%E4%B8%8B%E8%BD%BD%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%EF%BC%883.2.6%EF%BC%89%E6%97%B6%EF%BC%8C%E5%AE%83%E6%98%BE%E7%A4%BA%E5%AE%89%E8%A3%85%E4%B8%8D%E6%88%90%E5%8A%9F%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%86%8D%E6%AC%A1%E5%AE%89%E8%A3%85%E4%BB%A5%E5%89%8D%E7%9A%84%E7%89%88%E6%9C%AC%E6%97%B6%EF%BC%8C%E5%AE%89%E8%A3%85%E6%88%90%E5%8A%9F%E4%BA%86%E3%80%82%20%E4%BA%8E%E6%98%AF%EF%BC%8C%E6%88%91%E4%BF%9D%E7%95%99%E4%BA%86%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%E6%8F%92%E4%BB%B6%EF%BC%8C%E5%B9%B6%E6%8A%8A%E5%AE%83%E6%94%BE%E5%88%B0%E4%BA%86%E6%97%A7%E7%89%88%E6%9C%AC%E4%B8%AD%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%87%BA%E7%8E%B0%E4%BA%86%E6%9C%80%E5%88%9D%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221000016112.jpg%22%20style%3D%22width%3A%204096px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221000016112.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221000016112.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221000016112.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221000016112.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221000016112.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367327i5FD52434515BFFFE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%221000016112.jpg%22%20alt%3D%221000016112.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20canfd%20configuration%20of%20freemaster%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E8%AE%A9%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E8%A7%A3%E5%86%B3%203.2.6%20%E5%AE%89%E8%A3%85%E9%97%AE%E9%A2%98%E3%80%82%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%E6%96%B0%E7%89%88%E6%9C%AC%E6%97%B6%E4%BC%9A%E9%81%87%E5%88%B0%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FFreeMASTER%2FFails-to-reinstall-FreeMaster-3-0%2Fm-p%2F1066464%22%20target%3D%22_blank%22%3E%E6%9C%AC%E5%B8%96%3C%2FA%3E%E4%B8%AD%E6%8F%8F%E8%BF%B0%E7%9A%84%E4%B8%80%E4%BA%9B%E5%85%B8%E5%9E%8B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E8%83%BD%E5%90%A6%E5%B0%9D%E8%AF%95%E5%85%88%E5%8D%B8%E8%BD%BD%E6%97%A7%E7%89%88%E6%9C%AC%EF%BC%8C%E7%84%B6%E5%90%8E%E6%B8%85%E7%90%86%2F%E5%88%A0%E9%99%A4%20%3CEM%3E%3CSTRONG%3EC%3A%2FProgram%20Files%20(x86)%2FZero%20G%20Registry%5C.com.zerog.registry.xml%20%3C%2FSTRONG%3E%3C%2FEM%3E%E8%AF%A5%E5%B8%96%E5%AD%90%E4%B8%AD%E8%AE%A8%E8%AE%BA%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%B0%9D%E8%AF%95%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E5%AE%89%E8%A3%85%203.2.6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3EMichal%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2251857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20canfd%20configuration%20of%20freemaster%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2251857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%B8%8B%E4%B8%80%E6%AD%A5%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%81%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221764573947864.jpg%22%20style%3D%22width%3A%204096px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764573947864.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764573947864.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221764573947864.jpg%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367900i2E24F2B3FDA49208%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%221764573947864.jpg%22%20alt%3D%221764573947864.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2252888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20canfd%20configuration%20of%20freemaster%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2252888%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%0A%3CP%3E%E9%94%99%E8%AF%AF%E4%BB%A3%E7%A0%81%3CSTRONG%3E0x80070005%3C%2FSTRONG%3E%E8%A1%A8%E7%A4%BA%3CSTRONG%3E%E6%8B%92%E7%BB%9D%E8%AE%BF%E9%97%AE%E3%80%82%20%3C%2FSTRONG%3E%E6%88%91%E6%80%80%E7%96%91%E4%BD%A0%E5%9C%A8%E8%BF%90%E8%A1%8C%20cmd%20%E6%97%B6%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%22Run%20as%20administrator%22%20%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%20Windows%20%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E4%B8%AD%E6%89%BE%E5%88%B0%3CSTRONG%3Eregister.bat%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E4%BB%A5%E7%AE%A1%E7%90%86%E5%91%98%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%22%22%20%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22MichalH_0-1764660602834.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764660602834.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MichalH_0-1764660602834.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368164i5FB37273ED579B41%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MichalH_0-1764660602834.png%22%20alt%3D%22MichalH_0-1764660602834.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3EMichal%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20canfd%20configuration%20of%20freemaster%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%E6%88%91%E5%9C%A8%E5%AE%89%E8%A3%85%E8%BF%87%E7%A8%8B%E4%B8%AD%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E5%BD%93%E6%97%B6%EF%BC%8C%E6%88%91%E8%BF%98%E4%B8%8D%E9%9C%80%E8%A6%81%E8%BF%90%E8%A1%8C%E8%BF%99%E4%B8%AA%E6%96%87%E4%BB%B6%3C%2FP%3E%3C%2FLINGO-BODY%3E
