Support multi map file
1,654 次查看
sobo
we use Freemaster with an S32K358, it's a multicore project.
Each core have a software and a map file.
I don't find in Freemaster how to select 2 maps file to access variables of each core/ software .
So how can I do that ? if not how can we use Freemaster on multicore with 2 software ?
thank you
Sophie
标记 (2)
1,639 次查看
MichalH
NXP Apps Support
NXP Apps Support
FreeMASTER can only communicate to one target. This is similar to multi-processor setup, you can run multiple instances of FreeMASTERs and each can may communicate with one target core. Each core shall use a different serial port or different CAN frame identifiers.
In case you use a JTAG direct memory access, you could theoretically observe both operational memory areas used by the two cores using a single FreeMASTER session - in this case you need a mechanism how to join the two map files into one and parse it with a Regular expression parser. Unfortunately, FreeMASTER has no built-in support to simplify this task.
Michal
1,640 次查看
MichalH
NXP Apps Support
NXP Apps Support
Michal
%3CLINGO-SUB%20id%3D%22lingo-sub-2075095%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%94%AF%E6%8C%81%E5%A4%9A%E5%9C%B0%E5%9B%BE%E6%96%87%E4%BB%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075095%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E5%B0%86%20Freemaster%20%E4%B8%8E%20S32K358%20%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E5%A4%9A%E6%A0%B8%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%AF%8F%E4%B8%AA%E6%A0%B8%E5%BF%83%E9%83%BD%E6%9C%89%E4%B8%80%E4%B8%AA%E8%BD%AF%E4%BB%B6%E5%92%8C%E4%B8%80%E4%B8%AA%E5%9C%B0%E5%9B%BE%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E6%B2%A1%E6%9C%89%E5%9C%A8%20Freemaster%20%E4%B8%AD%E6%89%BE%E5%88%B0%E5%A6%82%E4%BD%95%E9%80%89%E6%8B%A9%202%20%E4%B8%AA%E5%9C%B0%E5%9B%BE%E6%96%87%E4%BB%B6%E6%9D%A5%E8%AE%BF%E9%97%AE%E6%AF%8F%E4%B8%AA%E6%A0%B8%E5%BF%83%2F%E8%BD%AF%E4%BB%B6%E7%9A%84%E5%8F%98%E9%87%8F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%82%A3%E4%B9%88%E6%88%91%E8%AF%A5%E6%80%8E%E4%B9%88%E5%81%9A%E5%91%A2%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E6%88%91%E4%BB%AC%E5%A6%82%E4%BD%95%E5%9C%A8%E5%A4%9A%E6%A0%B8%E4%B8%8A%E4%BD%BF%E7%94%A8%202%20%E4%B8%AA%E8%BD%AF%E4%BB%B6%E7%9A%84%20Freemaster%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%B4%A2%E8%8F%B2%3C%2FP%3E%3C%2FLINGO-BODY%3E
