How to retrieve embedded software freemaster info strings?
3,650件の閲覧回数
lucabarbiero
Hello, the FreeMASTER driver supports the following string defines:
- FMSTR_APPLICATION_STR
- FMSTR_DESCRIPTION_STR
- FMSTR_BUILDTIME_STR
Once I define them on target side, how can I retrieve these strings using the desktop application, as well as activex and json-rpc APIs? I could not find any documentation about this.
Luca
3,640件の閲覧回数
iulian_stan
Hi Luca,
You can get this values via ActiveX/JSON-RPC API using GetConfigParamString function with:
  • NM argument for FMSTR_APPLICATION_STR
  • DS argument for FMSTR_DESCRIPTION_STR
  • BD argument for FMSTR_BUILDTIME_STR.
Iulian
3 返答(返信)
3,637件の閲覧回数
lucabarbiero
Ok sorry, I just missed that! Why don't you add this feature in the desktop app as well? Maybe get those strings in a popup window or something. That would be useful.
Luca
3,607件の閲覧回数
MichalH
NXP Apps Support
NXP Apps Support
Hello Luca,
some of the application parameters (not the string ones though) are displayed when trying to use a Connection Wizard with an already connected board:
Your request has been logged. We'll extend this dialog in one of the future versions and will add a more obvious way to display it.
Michal
3,641件の閲覧回数
iulian_stan
Hi Luca,
Iulian
