How to deal with a null Plugin-Module in FREEMASTER?
3,713 次查看
William-Lee
I had installed the freemaster 3.1,and I want to use the PE-micro to monitor variables ,but the Plugin-Module is NULL.Do I need to install something else?Is there any body meet this situation?please give me a hand , thanks a lot .福昕截屏20220715105304376.PNG
3,708 次查看
MichalH
NXP Apps Support
NXP Apps Support
probably there was some problem for the installer to acquire administrator rights during installation. You should be able to fix it by running the "c:\NXP\FreeMASTER 3.1\FreeMASTER\register.bat" as administrator.
If this does not help, please re-install the FreeMASTER. First un-install the product and then install again by running the installer "as administrator".
Michal
3,709 次查看
MichalH
NXP Apps Support
NXP Apps Support
Michal
3,682 次查看
William-Lee
It works, thanks for your help!
