Freemaster lite activation issue
2,672件の閲覧回数
alexandrevalero
when installing Freemaster lite, the activation server cannot be reached and results in failure installation. see attached picture.
2,667件の閲覧回数
iulian_stan
Hi @alexandrevalero,
It seems to be known issue related to the activation library, see this post for more details.
There are 2 options you could try:
  1. Follow the steps described in the linked post :
    • Download the Activation archive
    • Extract the content to your local PC and open the terminal in the Activation folder
    • Execute the following command
      "java -Djava.library.path="cll/x64" -jar "license.jar" activateUI"
    • Use FreeMASTER Lite activation code, when it completes → launch the installer
      If the activation succeeded in the previous step - there should be no activation prompt during the new install
  2. Try an offline activation. The process is described in this post
In case none of these approaches work - you can unselect FreeMASTER Lite component during installation (this component triggers license activation flow).
PS: License activation mechanism will be removed in the next release (coming in May 2025).
