Freemaster Variable Comments
3,930件の閲覧回数
Bohrfutter
Hello
I am having an "old" project file which I moved to Freemaster 3.1. Now I can enter variable comments but I do not find any button to display them. Can you give any advice were to enable comments display?
Sebastian
3,918件の閲覧回数
MichalH
NXP Apps Support
NXP Apps Support
Hello Sebastian,
for the new projects, the comment is visible in the 5th column of a Variable Watch:
When loading older projects, the column is intentionally hidden (so the project looks the same as when saved). You can show the column in Watch properties:
Michal
2 返答(返信)
3,919件の閲覧回数
MichalH
NXP Apps Support
NXP Apps Support
Hello Sebastian,
Michal
3,913件の閲覧回数
Bohrfutter
Hi Michal,
the only place I haven’t look
Thanks!
Sebastian
