Freemaster Query
Freemaster Query
2,250 次查看
21
When I open MC9S12ZVML128_BLDC_Hall.pmp with FreeMASTER3.0, the following prompt appears. How do I solve this problem?
Error show-
1.symbol not found.
2.communication Error.
3.If started the communication then, not getting the values if variable
2,193 次查看
21
Yes, BLDC app is loaded in the target MCU Board.
PC through code worrier BLDC application code is loaded on MCU board through P&E debugger and then connect MCU board USB/SCI free master to PC through USB and opening project in Free master and starting Communication. There is communication error is show.
2,238 次查看
MichalH
NXP Apps Support
NXP Apps Support
do you have the BLDC application loaded in the target MCU board and is the board properly connected to the PC?
Please describe your hardware setup, what application you run in the MCU and how is your PC connected to the board.
Michal
