Editing LookUp Tables (Maps)
Sam_ECU
Contributor V
Does Freemaster have the capability to edit lookup tables during live measurements?
If so, how and how does the elf/map need to be set up?
Sam
MichalH
NXP Apps Support
NXP Apps Support
FreeMASTER is able to modify any variable, array element or structure member located in RAM. It can parse any ELF, nothing special is needed.
It very much depends on how your lookup tables are structured. You can always try to load the ELF into FreeMASTER and see what C symbols it parses.
Michal
