Can freemaster connect target device via Ethernet TCP?
1,867件の閲覧回数
Sharingan666
Hi,I want to connet my target device via Ethernet port, does freemaster support this function? I found TCP communcation configuraton in "Option" dialog, but can not find any introduction in freemaster softtware user guide. Can I use this communcation function?
Thinks.
2 返答(返信)
1,852件の閲覧回数
Sharingan666
Thanks very much, I will try another way.
1,858件の閲覧回数
MichalH
NXP Apps Support
NXP Apps Support
Dear user,
direct TCP or UDP communication is not yet available in FreeMASTER. We have it in our plans, but the release is not scheduled for this year.
You are correct that there is an experimental version of the TCP plug in in the list, but this is currently not usable.
Michal
