CAN communication protocol
ps_73453
Which communiation protocol is used for interaction with a decive connected via CAN bus?
Does FreeMaster use a proprietary bus protocol or is it the „CAN calibration Protocol“ (CCP) published by ASAM?
KalaimaniArumugamdev
hi @ps_73453
           FreeMaster using  proprietary bus protocol and here I add some reference document which I follow, This may clear you question.
