VSCode "Open MCUXpresso Installer" error
1,185件の閲覧回数
ajayad
o for operation 'HttpRequestHandler.get': Maximum number of retries exceeded. The operation 'HttpRequestHandler.get' failed with error: unable to get local issuer certificate. Technical details: {"message":"unable to get local issuer certificate","name":"Error","stack":"Error: unable to get local issuer certificate\n\tat TLSSocket.onConnectSecure (node:_tls_wrap:1674:34)\n\tat TLSSocket.emit (node:events:519:28)\n\tat TLSSocket._finishInit (node:_tls_wrap:1085:8)\n\tat ssl.onhandshakedone (node:_tls_wrap:871:12)","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"transformRequest":[null],"transformResponse":[null],"timeout":5000,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"headers":{"Accept":"application/json, text/plain, */*","User-Agent":"axios/0.26.1"},"responseType":"stream","proxy":false,"cancelToken":{"promise":{},"_listeners":[]},"method":"get","url":"https://www.nxp.com/lgfiles/updates/mcuxpresso/MCUXpressoInstaller.exe"},"code":"UNABLE_TO_GET_ISSUER_CERT_LOCALLY","status":null}
0 返答(返信)
