net-snmp subagent cross compiling
FEI-Namg
I am trying to compile a net-snmp subagent for arm64 but when compiling with aarch64-linux-gnu-gcc, it says that it skips incompatible library since one is arm64 and the other is x86, such as skipping incompatible /usr/lib/x86_64-linux-gnu/libnetsnmpmibs.so when searching for -lnetsnmpmibs
 So I changed how the subagent is being compiled to use arm64 libraries but I am still missing a few libraries such as -lsensors and -lwrap saying they no such file or directory.
If anyone could provide any insight, that would be greatly appreciated
Tags (3)
yisey
You need to install the ARM64 versions of all required development libraries (e.g., libsnmp-dev:arm64, libsensors4-dev:arm64, libwrap0-dev:arm64) and set the compiler, include paths, and library paths to use them. Ensure PKG_CONFIG_PATH points to ARM64 .pc files and use ./configure --host=aarch64-linux-gnu, or consult a BMW Service Near Me for guidance, so the compiler picks the correct architecture libraries instead of x86_64 ones.
%3CLINGO-SUB%20id%3D%22lingo-sub-2134469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Enet-snmp%20subagent%20cross%20compiling%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2134469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20compile%20a%20net-snmp%20subagent%20for%20arm64%20but%20when%20compiling%20with%20aarch64-linux-gnu-gcc%2C%20it%20says%20that%20it%20skips%20incompatible%20library%20since%20one%20is%20arm64%20and%20the%20other%20is%20x86%2C%20such%20as%20skipping%20incompatible%20%2Fusr%2Flib%2Fx86_64-linux-gnu%2Flibnetsnmpmibs.so%20when%20searching%20for%20-lnetsnmpmibs%3C%2FP%3E%3CP%3E%26nbsp%3BSo%20I%20changed%20how%20the%20subagent%20is%20being%20compiled%20to%20use%20arm64%20libraries%20but%20I%20am%20still%20missing%20a%20few%20libraries%20such%20as%20-lsensors%20and%20-lwrap%20saying%20they%20no%20such%20file%20or%20directory.%3C%2FP%3E%3CP%3EIf%20anyone%20could%20provide%20any%20insight%2C%20that%20would%20be%20greatly%20appreciated%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20net-snmp%20subagent%20cross%20compiling%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20need%20to%20install%20the%20ARM64%20versions%20of%20all%20required%20development%20libraries%20(e.g.%2C%20libsnmp-dev%3Aarm64%2C%20libsensors4-dev%3Aarm64%2C%20libwrap0-dev%3Aarm64)%20and%20set%20the%20compiler%2C%20include%20paths%2C%20and%20library%20paths%20to%20use%20them.%20Ensure%20PKG_CONFIG_PATH%20points%20to%20ARM64%20.pc%20files%20and%20use%20.%2Fconfigure%20--host%3Daarch64-linux-gnu%2C%20or%20consult%20a%20%3CA%20href%3D%22http%3A%2F%2Fautotechnic.us%2F%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EBMW%20Service%20Near%20Me%3C%2FA%3E%20for%20guidance%2C%20so%20the%20compiler%20picks%20the%20correct%20architecture%20libraries%20instead%20of%20x86_64%20ones.%3C%2FP%3E%3C%2FLINGO-BODY%3E
