integrate android 11 into pytech pollux
3,407 次查看
prashantha
I am building android 11 in pytech pollux board (aosp) and i need to enalbe android debugger(adb shell) in pytech pollux board which is based on i.MX 8M
Is there a default CONFIG_ option which needs to be turned on in phytec phyboard pollux board for this to work /
 which port should be connect to enable adb environment ??
can you please share method to enable adb in android 11 with respect to pytech pollux board
3,003 次查看
manu_d
I have a same question. Can someone from a community please answer to this question ? If it's a basic, please educate us.
