imxg2dclockoverlay failure on imx6 duallite
813件の閲覧回数
jasonfox
I'm working on porting an application to the imx6dl with yocto 4.9.88 kernel and having a problem with the g2d. (This is our 1st use of the dual lite.)
As a test, if I run  the command gst-launch-1.0 videotestsrc ! video/x-raw,framerate=30/1,width=1280,height=720,format=UYVY,interlace-mode=progressive ! queue ! imxg2dvideotransform ! imxg2dclockoverlay ! fakesink
I get the error g2d_open: fail with status -24
This happens with our application as well.  Anyone know what this error means?   Google has been of no help so far.
Thanks!
0 返答(返信)
