imx8mq-phanbell
imx8mq-phanbell
e34605
Hello I am using a coral SOM on a custom board that has a MIPI DSI. I am trying to enable it via the device tree. I am using the files fsl-imx8mq-phanbell.dts, fsl-imx8mq-som.dtsi, and fsl-imx8mq.dtsi. The dsi panel I am trying to connect is attached to this post. Any help with this would be greatly appreciated thank you.
