S32DS compilation error
leeli
S32DS compilation error program "gcc" not found in PATH; but it can be compiled and passed, what is the reason for this?
yinzc
Hi,i have the same problem,have you solved the problem now?
nxf57422
did you run export PATH=<path for gcc> ? Can you add build logs for additional info, thanks
Best,
Marco Cesarano
