RT1010 - USB OTG serial COM
2,975件の閲覧回数
info32
I'm working with the EVK-MIMXRT1010 board. Can I use the USB OTG port to connect a USB to UART converter and send/receive data as a virtual COM port? (I already know I can use the LPUARTs for serial COMs). If so, can you point me out to some example I can use as a starting point? Thanks!
2 返答(返信)
2,746件の閲覧回数
alex_rodriguez
We have USB examples in the SDK under <SDK_PATH>\boards\evkmimxrt1010\usb_examples
I think usb_device_cdc_vcom is the example you are looking for.
-Alex
2,746件の閲覧回数
info32
Thanks!
