Problems FRDM-K64F serial communication
2,508件の閲覧回数
alberto1_paolin
Hello Everybody,
I am using the FRMD K64F with simulink and I am experiencing several problems with the serial communication. In particular I can send values to the computer but I am not able to send values to the board. When i run the simulink command file, I see the serial communication led which switches on intermittently, but none data is passed to where I want it to be sent (in this case I would like just to switch on a led).
I attach a screenshot with the firmware on the right and the command simulink on the left.
Thank you in advance for the attenction.
0 返答(返信)
